I am new to LiveCycle Designer. Wondering if there is a way to add PDF metadata into XDP form?
I tried adding it into the XML source under the <x:xmpmeta> section, but the rendered PDF output file lost the metadata I added in the XDP.
<x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="Adobe XMP Core 4.2.1-c041 52.337767, 2008/04/13-15:41:00 ">
<rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#">
<rdf:Description xmlns:xmp="http://ns.adobe.com/xap/1.0/" rdf:about="">
<xmp:ModifyDate>2009-09-14T15:44:32+05:30</xmp:ModifyDate>
<xmp:CreateDate>2009-09-14T15:44:31+05:30</xmp:CreateDate>
<xmp:MetadataDate>2010-12-08T19:42:13Z</xmp:MetadataDate>
<xmp:CreatorTool>Adobe LiveCycle Designer ES 8.2</xmp:CreatorTool>
</rdf:Description>
<rdf:Description xmlns:xmpMM="http://ns.adobe.com/xap/1.0/mm/" rdf:about="">
<xmpMM:DocumentID>uuid:129e34eb-49a8-43f4-a934-43f67f5d6891</xmpMM:DocumentID>
<xmpMM:InstanceID>uuid:ee103292-b266-4bb8-b1d1-71d29fe339e2</xmpMM:InstanceID>
</rdf:Description>
<rdf:Description xmlns:dc="http://purl.org/dc/elements/1.1/" rdf:about="">
<dc:format>application/pdf</dc:format>
</rdf:Description>
<rdf:Description xmlns:pdf="http://ns.adobe.com/pdf/1.3/" rdf:about="">
<pdf:Producer>Adobe LiveCycle Designer ES 8.2</pdf:Producer>
</rdf:Description>
<rdf:Description xmlns:ABC="ABC (http://www.abc.com)" rdf:about="">
<ABC:XYZ><?xml version="1.0" encoding="utf-8"?>
< xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns="http://www.abc.net/API/3.0">
</ABC:XYZ>
</rdf:Description>
<rdf:Description xmlns:desc="http://ns.adobe.com/xfa/promoted-desc/" rdf:about="">
<desc:version rdf:parseType="Resource">
<rdf:value>8.0.1291.1.339988.308172</rdf:value>
<desc:ref>/template/subform[1]</desc:ref>
</desc:version>
</rdf:Description>
</rdf:RDF>
</x:xmpmeta>
Appreciated!
lcfun
Views
Total Likes
You will need to manipulate the template.
John Brinkman decribed how this can be done:
http://blogs.adobe.com/formfeed/2009/05/template_transformation.html
Views
Total Likes
Thanks! I need to save the form as XDP and this technique doesn't work with XDP.
Views
Total Likes
Hmm, why should it not work?
In Designer you generally work with XDP.
The only difference is the file format you can select when you save the forms.
Views
Total Likes
The document states: "It also does not work when you save as .XDP. "
My form needs to be saved as .XDP.
Views
Total Likes
Ohh, I see.
But I think you can do this in a workaround with PDF, like the following.
1. Load a form in Designer
2. Delete possibly existing metadata in the XML Source <desc> ... </desc>
3. Add fragment with the scripting for the metadata changes
4. Save as PDF
5. Close the PDF
6. Reopen the PDF
7. Save as XDP
Views
Total Likes
