0 Replies Latest reply on Dec 8, 2010 2:30 PM by DrDTP
    mysql select statement where = works and LIKE fails
    DrDTP
      I am using Flash Builder 4. On the server side I use php and mysql. I created a php dataservice using FB4. My plan had been to allow users to enter a search term and query the database using a "LIKE" statement. FB4 created the php code that I simply modified changing the parameter name. The input parameter is a string.
      public function getT_caseByID($searchTerm) {
      $stmt = mysqli_prepare($this->connection, "SELECT * FROM $this->tablename WHERE (title = ?)");
      $this->throwExceptionOnError();
      mysqli_stmt_bind_param($stmt, 'i', $searchTerm);
      mysqli_stmt_execute($stmt);
      mysqli_stmt_bind_result($stmt, $row->idt_case, $row->title, $row->id_author, $row->comments);
      if(mysqli_stmt_fetch($stmt)) {
            return $row;
      } else {
            return null;
      A look at FB4 shows this code returns data.
      This code works fine but if I make the below change it fails, even when I use the wildcard %. the only change is "=" to "LIKE".
      $stmt = mysqli_prepare($this->connection, "SELECT * FROM $this->tablename WHERE (title LIKE ?)");
           return $row;
      } else {
           return null;
      A look into FB4 shows "void".
      Any help would be appreciated. I am using localhost on Apache Server on a development computer with Windows XP.
