6 Replies Latest reply on Dec 12, 2010 6:35 AM by real_ideveloper
    FontFamily in spark Flex 4
    real_ideveloper
      Hi.
      For my current project I am using spark components from the Flex 4.
      I have some embedded fonts which I include with a css-file.
      When I try to set the fontFamily, for example for the spark.component.textarea, the textarea displays System Arial font.
      When I change the compiler to Flex 4.1 the spark component displays the embedded font.
      Is it a bug in the version 4.0 or do I make something wrong?
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:ns="library://ns.adobe.com/flex/spark">
        <mx:Style source="fonts.css"/>
        <ns:TextArea fontLookup="embeddedCFF" fontFamily="TimesItalic" heightInLines="NaN" widthInChars="NaN" x="300" y="50" text="Embedded Font"/>
      </mx:Application>
      CSS:
      @font-face {
              src: url("Families/TIMES_IT.TTF");
              fontFamily: TimesItalic;
              embedAsCFF: true;
        • 1. Re: FontFamily in spark Flex 4
          Peter deHaan Level 4
          Possibly.
          There were a number of bug fixes between the Flex 4.0 and 4.1 releases (as well as an upgrade TLF).
          This seems to work as expected in Flex Hero:
                         xmlns:mx="library://ns.adobe.com/flex/mx">
              <s:controlBarContent>
                  <s:Button id="sdkVer" initialize="sdkVer.label = mx_internal::VERSION;" click="System.setClipboard(sdkVer.label);" />
              </s:controlBarContent>
              <fx:Style source="fonts.css"/>
              <s:TextArea text="Embedded Font"
                          fontStyle="italic"
                          x="300" y="50" />
          </s:Application>
          And my fonts.css is as follows:
          /* CSS file */
          @namespace s "library://ns.adobe.com/flex/spark";
          @namespace mx "library://ns.adobe.com/flex/mx";
          @font-face {
              src: url("C:/Windows/Fonts/times.ttf");
          @font-face {
              src: url("C:/Windows/Fonts/timesi.ttf");
              fontStyle: italic;
          Peter
          • 2. Re: FontFamily in spark Flex 4
            real_ideveloper Level 1
            Hi Peter.
            I tried you code. It does not work.
            It only works with the version 4.1. I have noticed that the loading time of the version 4.5 is faster, therefore I would like to use the version 4.5.
            Here is a screenshot of my comparing results
            The player versions are 10.0 (on the left) and 10.1 (on the right).
            What am I doing wrong?
            • 3. Re: FontFamily in spark Flex 4
              Are you using the code I posted, or is your code somewhat different? If your code is different, can you post your entire small test case here and I can take a look.
              I was using the latest public Hero release (4.5.0.18623 from Tue Nov 30, 2010, and a beta version of Flash Player 10.2).
              Peter
              • 4. Re: FontFamily in spark Flex 4
                Hi Peter.
                I have taken your code, which you posted above.
                (Copy-Paste)
                I will try it again today with the newer version of SDK.
                • 5. Re: FontFamily in spark Flex 4
                  What if you try upgrading to the Flash Player 10.2 beta?
                  Peter
                  • 6. Re: FontFamily in spark Flex 4
                    Hi, Peter.
                    It works with the new Hero version (4.5.0.18623) and the Player verion 10!!!!!
                    The loadin time is fast.
                    But now I have a new Problem.
                    Assigning a new font family for the mx:Label results in an empty text of the label.
                    (I know I could take the s:Label and it would be working, but why does it not work with the mx:Label? Is mx-package deprecated?)
                                    fontStyle="italic"
                                    x="300" y="50" />
                    <mx:Lable text="Lable Text" "TimesItalic"
                                    fontStyle="italic"
                                    y="300" y = "200"/>
                    </s:Application>
