7 Replies Latest reply on Dec 9, 2010 9:25 AM by r.rubio
    Multi-Version Using Flex 4.1 SDK
    r.rubio
      Setup
      Flex SDK - 4.1
      -includes=mx.managers.systemClasses.MarshallingSupport
      Player 10.1
      I'm trying to try out multi-version support.  My configuration is as follows:
      1.  boostrap loader loads a portal (both bootstrap and portal compiled using 4.1)
      2.  portal loads a 3.5 compiled application
      I get the following error:
      VerifyError: Error #1053: Illegal override of activate in mx.managers.SystemManagerProxy
      The portal is loaded as a child of bootstrap as follows:
      swfLoader.loaderContext.applicationDomain = new ApplicationDomain(bootStrapApplicationDomain);
      The portal loads the 3.5 application as a child of boostrap as follows:
      Am i missing a step?
        • 1. Re: Multi-Version Using Flex 4.1 SDK
          r.rubio Level 1
          When i use the logic in SWFLoader to get bootstrap or top level app domain i get null for the ApplicationDomain but it gets farther as the swf file is actually loaded.  But i then get the expected typecoercion errors since it is not loaded as a child of bootstrap.
          SWFLoader uses the following logic:
          var appDomain:ApplicationDomain = currentDomain.parentDomain;
          var topmostDomain:ApplicationDomain = null;
          while (appDomain)
               topmostDomain = appDomain;
               appDomain = appDomain.parentDomain;
          lc.applicationDomain = new ApplicationDomain(topmostDomain);
          As mentioned previously if i use the boostrap application domain i get the error mentioned in previous post:
          Any ideas?
          • 2. Re: Multi-Version Using Flex 4.1 SDK
            joan_lafferty Adobe Employee
            To load the 3.5 Flex SWF into a 4.1 application, you'll need to load it into the SWFLoader and use loadForCompatibility=true. This will load the SWF into its own application domain so that classes don't clash for the different versions. I didn't see that you mentioned using loadForCompatibility.
            hope this helps,
            Joan
            • 3. Re: Multi-Version Using Flex 4.1 SDK
              r.rubio Level 1
              When you specify loaderContext in SwfLoader loadForCompatibility is ignored.  When i use loadForCompatibility the parent application Domain used is "null" which works but causes type coercion errors for classes that i want to share across the domains.
              This problem is suppose to be solved by the bootstraploader but i cannot get it to work on a multi-version configuration.
              • 4. Re: Multi-Version Using Flex 4.1 SDK
                Flex harUI Adobe Employee
                Get a link-report for the bootstrap.  Make sure SystemManagerProxy is not in
                the bootstrap
                • 5. Re: Multi-Version Using Flex 4.1 SDK
                  r.rubio Level 1
                  What would cause it to be included?
                  I also created vanilla boostrap and portal with only required imports on boostrap but i still get same error when i use boostrap app domain.
                  How do i prevent SystemManagerProxy from being included.
                  • 6. Re: Multi-Version Using Flex 4.1 SDK
                    The link-report should tell you how it got in there.   Bootstraps may not
                    always be possible.
                    • 7. Re: Multi-Version Using Flex 4.1 SDK
                      r.rubio Level 1
                      Thanks.  Got it.  MarshalSupport flag was set in bootstrap and was causing error.  Should only be set in portal application.
