4 Replies Latest reply on Dec 13, 2010 5:45 AM by etienne4life
    Using checkbox ?
    etienne4life Level 1
      Hello all,
      do you know if it is possible to add interaction on a checkbox (wireframe components).
      If i select a checkbox, i don't find it in the interaction panel.
      I'm trying to do something like that:
      On clik on this checkbox show me this components.
      Don't hesitate to ask me for more explanations if you don't understand my english.
      Thx a lot.
      Etienne
      Win xp, Flash Catalyst CS5
        • 1. Re: Using checkbox ?
          Chris W. Griffith Adobe Community Professional
          The checkbox can have the On Click interaction applied to it. What exactly do you want to occur after the user checks the component?
          Chris
          • 2. Re: Using checkbox ?
            Thank you for your answer,
            i am working with french version of flash catalyst, and i don't really know the good terms used for the english one.
            So i will try to find good words for a better understanding.
            if i began a project from scratch. i use only a checkbox an a CustomComponent with two states (state 1 (( <-default state))  and state 2). All in the same page (impossible for me using two differents pages)
            I would like something like that.
            1) customer click the ckeckbox -> custom component runs from state 1 to state 2
            2) customer click a second time the checkbox ->custom component runs from state 1 to state 2
            - I select the checkbox, then, in the interactive panel, i do this:
            For all (any?)  states, read transition for CustomComponent  to state 1 to state 2.
            It works well.
            Check box is still selected, For all (any?)  states, read transition for CustomComponent  to state 2 to state 1.
            It doesn't work.
            I think it's normal, because it seems to be conflicting.
            My problem is that i can't choose the state of the checkbox because it's not in the list:
            I did my best to describe the situation.
            I hope you will have a better understanding of the situation.
            Once again, thanx a lot.
            Etienne
            • 3. Re: Using checkbox ?
              Etienne-
              I think I get it. With Flash Catalyst 1.0, I think you are stuck. Flash Catalyst 1.5 might resolve this, but can't confirm it will. The best solution would be to add this little bit of functionality via Flash Builder.
              Chris
              • 4. Re: Using checkbox ?
                Thx a lot,
                best regards
                ETienne
