1 Reply Latest reply on Mar 25, 2011 3:25 AM by DHMerritt
    Creating an AIR application that connects to Adobe Connect
    DHMerritt Level 1
      I would like to use Flash Builder to create an AIR application that will talk to Adobe Connect. Is there anywhere I can go in order to read up on how to do this?
      Thank you
      Dimitri
        • 1. Re: Creating an AIR application that connects to Adobe Connect
          DHMerritt Level 1
          Ok I figured this one out with help form Kapil (thanks Kapil).
          Here are a few lines of code that is needed:
          <s:HTTPService id="myPersonalInfo" fault="faultHandler(event) resultFormat="e4x" result"personalInfo(event)"/>
          Then create a function e.g.
          private function requestPersonalInfo():void{
          domainUrl="your url.com";
          personalInfoRequest="";
          personalInfoRequest=domainUrl+api_xml_string;
          personalInfoRequest+="common-info";
          myPersonalInfo.url=personalInfoRequest;
          myPersonalInfo.send();
          private funtion personalInfo(event:ResultEvent):void{
          personalName=event.result.common.user.name;
          Username.text="Welcome" + personalName;
          Thats it.
