2 Replies Latest reply on Dec 10, 2010 7:19 AM by Ben Danis
    Dynamic Set Style
    Ben Danis Level 1
      I am creating my own type of button with HTML text and a bunch of other visual assets that have to be added dynamically.
      on Rollover, i'm trying to do a
      txt.setStyle("color", 0xFCAF17) // value tried as string as well '#FCAF17'
      and
      txt.setStyle("fontWeight", "bold")
      but it refuses to change the color or the weight, i've tried adding after
           txt.htmlText = txt.htmlText, but it doesn't change the color
      as well as updating display list.
      I've also tried
           var ct:ColorTransform = new ColorTransform();
           ct.color = 0x0xFACF17
           txt.transform.colorTransform = ct;
      but that also colors the drop shadow filter applied to it.
      also tried doing a bindable variable for the color but that doesn't work either
      I know that documentation says to avoid setStyle as it is computation heavy.  But i don't see any other way
      is there a way to do this without adding <font> tags to my html text?
        • 1. Re: Dynamic Set Style
          bKartik.b
          I am not sure if i understand that you are looking for but if you are trying to change the
          color of the text on rollOver you can use the "textRollOverColor".
          • 2. Re: Dynamic Set Style
            Ben Danis Level 1
            I'm trying to create a custom button with a text component for html text display.  On rollover trying to change the color of text (textRollOverColor doesn't work if text is html) and on click i want to make it bold
            If i set the property text instead of htmlText, it seems to work, although not ideal in this case
