3 Replies Latest reply on Dec 13, 2010 11:47 AM by dying veteran
    Requesting tutorial examples of setTimeOut()
    RainbowChunChunChang Level 1
      How does the operation of the two blocks differ ? The intent is to have a delay
      app.setTimeOut("function1()",1001); // Is the delay of 1001ms before or after function1() call ?
      app.setTimeOut("function2()",1002);
      app.setTimeOut("function3()",1003);
      app.setTimeOut("function4()",1004);
      Do all the setTimeOut() calls initiate almost parallel threads ? or one after another ?
      I have given slighty different times to be able to identify the function just by its time
      for the convenience of anyone replying.
      Any demo example to clarify its meaning ?
      Rainbow Chang
        • 1. Re: Requesting tutorial examples of setTimeOut()
          Bernd Alheit Adobe Community Professional & MVP
          Adobe Acrobat and Adobe Reader uses only one thread.
          • 2. Re: Requesting tutorial examples of setTimeOut()
            Sorry, not very clear.
            What is the sequence of time delay and execution ?
            I want a time delay between the functions. They can be something as simple as moving from one named destination to another in a file.
            Would you have an example I can execute in the debugger ? And if you show me how to place break points etc.
            I dont seem to figure out how to place breakpoints. I am using writer.
            Rainbow Chang
            • 3. Re: Requesting tutorial examples of setTimeOut()
              dying veteran Level 1
              1. Dec 9, 2010 8:56 AM  in response to: RainbowChunChunChang
              RainbowChunChunChang > Do all the setTimeOut() calls initiate almost parallel threads ? or one after another ?
              Bernd Alheit > Adobe Acrobat and Adobe Reader uses only one thread.
              Even if his comment is not lying, it is certainly misleading you.
              In the code fragment below
              setTimeOut( "f();" , 5000 ) ;
              g() ;
              the setTimeOut is executed and right away the execution passes to g(), while the setTimeOut waits 5s before executing f() , the execution of g() has already started and even completed.
              You should try some color change example because that is more amenable to a debugger than jumping or alert box.
              Dying Soldiers in Afghanistan
