4 Replies Latest reply on Dec 10, 2010 4:06 AM by Adam Cameron.
    Synchronizing with network share?
    wmiller453 Level 1
      Is there a way to synchronize local workspace files in CFBuilder with a network share? I see the FTP options but these won't work for me as I just need to push the files over to a shared drive on our development server (Like you can do in Dreamweaver).
        • 1. Re: Synchronizing with network share?
          Owain North Level 4
          If there's no CFB answer you could always just use something like Robocopy (crap name, okay product) to duplicate the folders, albeit manually.
          Can you not just edit the files directly on the network share if that's what you need? That's what I do here.
          • 2. Re: Synchronizing with network share?
            wmiller453 Level 1
            Editing the files directly on the server is an option as that is what we did before having CFB but since using CFB I thought it would be a good idea to have the files I'm working on located in my own workspace and then when I'm done testing move them to the staging server. It'd be nice if CFB had an option like dreamweaver to just synchronize with a network share. One IDE for them all!!!! LOL
            • 3. Re: Synchronizing with network share?
              Owain North Level 4
              As CFB is just built on Eclipse, there are probably many plugins you can get that'd do this - I just found one called FileSync which should do the job you're after, but have a Google and see what suits you.
              Never used any of them myself (disclaimer, etc) but it's a fairly simple task so I'm sure someone has written something decent.
              O.
              • 4. Re: Synchronizing with network share?
                Adam Cameron. Level 5
                Doesn't source control cover that for you?  Work locally, commit your stuff, when you're ready to deploy your changes, run an update on the other environment (obviously with some branching & tagging going on in the middle of all that, as appropriate).
                I don't see deployment of code being the job of the IDE.
                Adam
