4 Replies Latest reply on Dec 13, 2010 12:51 PM by Ladislav Navrátil
    Handling custom event from HeaderRenderer of DataGrid
    Ladislav Navrátil Level 1
      Hi all,
      i have following problem:
      I have headerRenderer,where i have custom event:
      <fx:Metadata>
           [Event(name="changeName", type="Events.ColumnEvent")]
      </fx:Metadata>
      my class with custom event looks like this:
      package Events
           import flash.events.Event;
           public class ColumnEvent extends Event
                    public static const CHANGE_NAME:String = "changeName";
                     public static const DELETE:String = "delete";
                     public var name:String;
                     public function ColumnEvent(type:String, bubbles:Boolean=false, cancelable:Boolean=false)
                          super(type, bubbles, cancelable);
                     override public function clone():Event{
                          var newEvent:ColumnEvent = new ColumnEvent(type);
                          newEvent.name = name;
                          return newEvent;
      when somethings happends in my headerRenderer, it calls this functions, which dispatch my custom event:
      protected function header_changeHandler(event:TextEvent):void{
           var columnEvent:ColumnEvent = new ColumnEvent("changeName");
           columnEvent.name = event.text;
           dispatchEvent(columnEvent);
      and finally here i set up headerRenderer and set up listener of my event:
      //create instace of class which inherit from DataGridColumn, so column is DataGridColumn data type can i say.
      var column:Column = new Column("~column"+table.columns_arr.length);
      //create class factory of headerRenderer
      var headerFactory:ClassFactory= new ClassFactory(DataHeader_DataGrid);
      //set propertie
      headerFactory.properties = {header:"My HEADER"};
      column.headerRenderer = headerFactory;
      //here i set up listener, but onHeaderChange function isnt called, when i dispatch my custom event
      column.addEventListener(ColumnEvent.CHANGE_NAME, onHeaderChange);
      table.AddColumn(column);//add new column to columns array
      table_datagrid.columns = table.columns_arr;//update array of columns to datagrid
      thank you very mutch and sorry for my english !
      Message was edited by: Ladislav Navrátil
