3 Replies Latest reply on Dec 13, 2010 7:55 PM by Vishesh Bagga
    Contrato de Licencia de adobe presenter
    Vladimir T
      SISTEMA OPERATIVO
      WINDOWS 7 ENTERPRICE
      3GB RAM
      MICROSOFT OFFICE 2010
      ADOBE SUITE X
      MI PROBLEMA ES QUE CUANDO INICIO MICROSOFT POWER POINT 2010  Y VOY A UTILIZAR ADOBRE PRESENTER LA VERSION 7.06
      ME SALE EL CONTRETO DE LICENCIA DE ADOBE
      LOE DOY ACEPTAR PERO NOHACE NADA
      LE DOY DECLINAR Y TAMPOCO
      LE DOY CANCELAR Y NO HACE NADA
      ¿¿COMO PUEDO SOLUCIONAR ESTE INCOMBENIENTE ???
      MUCHAS GRACIAS
        • 1. Re: Contrato de Licencia de adobe presenter
          Vishesh Bagga Level 1
          Would be kind of you if you could provide an English Translation
          for the problem being talked about
          But what i could gather from the description is that you are facing problem activating Presenter installed via Acrobat Suite on a Office 2010 system...correct me if i am wrong
          If that is the case do let us know so that we can investigate the exact issue
          • 2. Re: License Agreement adobe presenter
            Vladimir T Level 1
            OPERATING SYSTEM
            WINDOWS 7 ENTERPRICE in English
            3GB RAM
            MICROSOFT OFFICE 2010 in English
            ADOBE SUITE X in English
            MY PROBLEM IS THAT WHEN HOME MICROSOFT POWERPOINT 2010 AND I WILL USE PRESENTER ADOBRE version 7.06
            I get the stud ADOBE LICENSE
            DO I DO NOTHING BUT OK
            DECLINE AND DOES NOT GIVE
            DO I CANCEL AND DO NOTHING
            "HOW CAN I SOLVE THIS INCOMBENIENTE??
            DO NOT REMOVE THE CONTRACT
            TOCA ME CLOSE THE POWER POINT PROCESS 2010 FOR THE TASK MANAGER
            THANK YOU
            • 3. Re: License Agreement adobe presenter
              After you launch PowerPoint after installing the same from Acrobat Suite X
              and go to the Adobe Presenter Tab and try to use any of its functionality, you will get the End User License Agreement which you need to Accept to continue using the functionality of Adobe Presenter
              If you have used a valid license key for Acrobat Suite X, Adobe Presenter will be activated automatically
              If you are in a Trial run you will get a screen showing that you are in Trial mode and the number of days left in your Trial
              In case your Trial period has expired, you need to buy a Valid License key and run the installer for Acrobat Suite X again and this time enter the license key and choose to install only Adobe Presenter to continue using Presenter
