0 Replies Latest reply on Dec 11, 2010 4:01 PM by catalyst99
    [PE9] How do I achieve my desired bit rate?
    catalyst99
      I would like for my video to have a bit rate of roughly 1.5 mbps. Unfortunately, I can't seem to get anywhere near. My last attempt with the setings below rendered the video at 247kbps.
      Basic Video Settings
      Codec: MainConcept MPEG Video
      Quality: 5
      TV Standard: NTSC
      Frame Width: 720
      Frame Height: 480
      Frame Rate: 29.97
      Display Format: Drop Frame
      Field Order: Lower
      Pixel aspect ratio: Widescreen 16:9
      Render at maximum depth: Checked
      Bitrate settings
      Bitrate encoding: VBR 2 pass
      Minimum bitrate: 1.5 mbps
      Target bitrate: 1.5 mbps
      Maximum bitrate: 2 mbps
      GOP settings
      M frames: 3
      N frames: 15
      Your help would be appreciated.
      Many thanks,
      David
