3 Replies Latest reply on Dec 13, 2010 4:38 PM by Fayena
    difference in array behavior between php and flex?
    Fayena
      I think this problem is probably caused by a difference in array behavior between php and flex that I'm not quite grasping.  This is the flex code that I have written and the php code is posted below it.  I'm new to flex and this really has me stumped.    Thanks much for your help.
      Inputs are sire=[SB1,kit] dam=[kit,kit] sireLinkedP=[E,P],[e,P]
      Output should be (and is with PHP) random=[E,P,SB1],[E,P,kit],[e,P,SB1],[e,P,kit]
      What I'm getting is random=[E,P,SB1,kit],[E,P,SB1,kit],[e,P,SB1,kit],[e,P,SB1,kit]
      function randomlinks(sire:Array,dam:Array,sireLinkedP:Array):Array{
      var str:String = sire[0].toUpperCase();
      var str1:String = sire[1].toUpperCase();
      var str2:String = dam[0].toUpperCase();
      var str3:String = dam[1].toUpperCase();
      var x:uint = sireLinkedP.length;
      var k:uint = 0;
      var random:Array = new Array();
      x--;
      trace("randomlinks sirelinked:" + sireLinkedP);
      for (var i:uint = 0;i<=x;i++){
            for (var j:uint = 0;j<=1;j++){
                random[k]= sireLinkedP[i];
                trace("random" + k + ":" + random[k]);
           if (str==sire[0]|| str1==sire[1]|| str2==dam[0] || str3==dam[1]) {
                random[k].push(sire[j]);
           }//end if
           k++;
           }//end for loop
      }//end for loop
      trace("randomlinks:" + random);
      return(random);
      }//end function randomlinks
      function randomlinks($sire,$dam,$sirelinked){
      $x=count($sirelinked);
      $x--;
      $k=0;
      for ($i=0;$i<=$x;$i++){
          for ($j=0;$j<=1;$j++){
              $random[$k]=$sirelinked[$i];
      if  (ctype_upper($sire[0]) || ctype_upper($sire[1]) || ctype_upper($dam[0]) || ctype_upper($dam[1])){
      array_push($random[$k],$sire[$j]);}
              $k++;
      return($random);
