3 Replies Latest reply on Dec 14, 2010 6:16 AM by Ned Murphy
    How to  randomly create variable from XML
    harshnsweet
      Hi guys,
      Need your help.
      I want to create random objects on to the stage through and xml.
      If u refer the image attached. each circle represents a data from the XML.
      i want these to get generated on to the screen randomly with easing animation.
      note: circles should have random 3-4 colors as mentioned.
      thenx in advance.
      --Harsh
        • 1. Re: How to  randomly create variable from XML
          What have you tried so far and what is not working for you?
          • 2. Re: How to  randomly create variable from XML
            harshnsweet Level 1
            in first frame of mail fla.
            import fl.motion.Color;
            import flash.geom.ColorTransform;
            var numberOfParticles:Number=20;
            var particlesArray:Array = new Array();
            var numberOfExplosionParticles:uint=10;
            for (var i=0; i < numberOfParticles; i++) {
            var particle:Particle = new Particle();
            particle.speedX=0;
            particle.speedY=0;
            particle.y=Math.random()*stage.stageWidth;
            particle.x=Math.random()*stage.stageHeight;
            addChild(particle);
            particlesArray.push(particle);
            particle.as file:
            package {
            import flash.display.MovieClip;
            public class Particle extends MovieClip {
            public var speedX:Number;
            public var speedY:Number;
            public var partOfExplosion:Boolean=false;
            function Particle():void {
            by this i was able to get random particles on stage.
            i am trying to create each particle representing a data in xml.
            --Harsh
            • 3. Re: How to  randomly create variable from XML
              That is all AS3 code, not AS2.  You need to repost in the AS3 forum... and include what you have tried and describe what is not working for you.
