2 Replies Latest reply on Dec 13, 2010 8:28 AM by Todd_Kopriva
    After effects layers do not show
    jameslivingstone Level 1
      Hi can anyone help me,
      I've looked around for lots of tutorials and nobody seems to have this simple problem.
      When I create a layer in CS5 it dosnt show the layer. Just a box - usually black.
      So, lets guide you a bit through the problem.
      I load after effects up.
      I click on new composition - I leave all the settings as default.
      I click ok.
      (It dosnt matter what back ground color I select, the screen is always black when I have clicked ok).
      No matter what I do from here nothing happens.
      If I click the txt Icon and type something, no matter what color txt I select it cannot be seen.
      If I then click the selection tool a box appears around where the txt should be so it is definitly there - but no matter what color I select this is what happens.
      If I then click on new layer (again leaving everything defaulted) I get a new layer but I just get like a wireframe X across it.
      This happens no matter what I do.
      The only way to change this is if I mess around with the roto brush and then go back to the original compisition box I can see my txt against a white and grey checked background!!!!
      Can anyone help because ive been trying to use since installing 2 days ago!!!
      Thanks in advance.
