1 Reply Latest reply on Dec 13, 2010 8:31 AM by Steve Grisetti
    Export to DVD format - PAL...
      Does anyone know the correct fomat for exporting to PAL screens (oldformat) I have done an export in DV format and the export got too wide for the screen...?
        • 1. Re: Export to DVD format - PAL...
          Which version of the product are you using and which method are you using to output your file?
          If you've got your project set up correctly, you should get a widescreen DVD if you use Share/Disc/DVD.
          You also don't say if you're original project is PAL or NTSC -- but if it's an NTSC video file,  you may find that simply outputting a PAL DVD from it may not go smoothly. They're very different formats.
