4 Replies Latest reply on Dec 13, 2010 7:44 AM by Claudiu Ursica
    event:Event ["data"] question
    VirtualCoder Level 1
      The following function is inside of a YouTube API class the I found googling.  It handles state changes  In copied this function into my app because I need to listen to and consume some of the same events.  My function is being fired at the correct times except that event["data"] is throwing the following run time error at me.
      ReferenceError: Error #1069: Property data not found on flash.events.Event and there is no default value.
      private function onPlayerStateChange(event:Event):void {
      // Event.data contains the event parameter, which is the new player state
      var stateIndex:Number = event["data"];
      switch(stateIndex){
      case 0: clearInterval(this.updateInterval);break;
      case 1: updateInterval = setInterval(function():void{
      currentTime = player.getCurrentTime()*1000;
      }, 500); break;
      case 3: this.duration = this.player.getDuration()*1000; break;
      this.dispatchEvent(event);
      Thanks for you help,
      VC
