1 Reply Latest reply on Dec 13, 2010 8:08 PM by tfi productions 44
    Premiere won't stop processes after closing
    DStoneburner
      I have the latest 5.03 update and Premiere will not stop in the computer processes after closing.  I have to manually stop the process in the task manager.  I'm running Win 7 64bit enterprise on a Core 2 duo E8600 3.33ghz and 8 gigs of ram.  I'm not sure why it's not closing completely.  Any help would be appreciated.
        • 1. Re: Premiere won't stop processes after closing
          tfi productions 44 Level 1
          hello,
          i am not a professional
          however i have noticed multiple threads in this forum
          about ppro not closing down and users have to kill the process
          what i have found is that with a little bit more patience,
          ppro will close down
          i think it depends on your system resources
          and how big your project is
          the lower the resources of your computer
          and the larger the project
          (and how long you've been using ppro since a 'fresh start')
          make for a longer time until ppro closes itself down
          as a test: edit how you usually do, then exit out of ppro
          and then watch in task manager's processes that ppro
          will 'eventually' close itself
          the more memory ppro uses
          the longer it takes to shut itself off
          hope this helps
          peaceiteasy,
          jeffrey
