3 Replies Latest reply on Dec 13, 2010 3:25 PM by Peter deHaan
    Spark DataGrid Help
    mdmave
      Where does one look to find examples on the Spark DataGrid? I know its bleeding edge but I can't find much info on how to use it.
      Specifically, I have two arrays: One with the column data such as [['name', 'string'], ['age', 'int']] and another with row data, such as [[dave, 30], [ray, 29], [jason, 25], [sara, 30]].
      I'd like to have a datagrid bound to these arrays, but not sure how. I'm building a dynamic data browser and it would help to have some info around setting columns dynamically. I played around with creating one array, and giving it objects such as columns, and rows with the data outlined above. Thats not helping either.
      THanks for any direction,
      D
        • 1. Re: Spark DataGrid Help
          Peter deHaan Level 4
          Not sure about your exact nested array example, but here is a basic example on how to use your data in a Spark DataGrid control:
          <s:DataGrid>
              <s:columns>
                  <s:ArrayList>
                      <s:GridColumn dataField="name" />
                      <s:GridColumn dataField="age" />
                  </s:ArrayList>
              </s:columns>
              <s:dataProvider>
                  <s:ArrayCollection>
                      <fx:Object name="dave" age="30" />
                      <fx:Object name="ray" age="29" />
                      <fx:Object name="jason" age="25" />
                      <fx:Object name="sara" age="30" />
                  </s:ArrayCollection>
              </s:dataProvider>
          </s:DataGrid>
          Peter
          • 2. Re: Spark DataGrid Help
            mdmave Level 1
            Thanks Peter,
            I should have been more clear the data/arrays that I am using are brought back from a separate class asynchronously:
            var tableName:String = event.currentTarget.selectedItems[0];
            tableMap[tableName] = {};
            controller.getTableInfo(tableName, function(data:Array):void
            tableInfo.source = data.map(function (element:RowData, index:int, array:Array):String {
            return element.getColumnAsString(1) + " (" + element.getColumnAsString(2) + ")";
            tableMap[tableName].label = tableInfo;
            dataGrid.columnHeaderBar.labelField = "label";
            controller.selectAll(tableName, function(data:Array):void
            tableMap[tableName].data = data;
            dataGrid.dataProvider = new ArrayCollection(tableMap[tableName].data);
            Right now I am close, but the column headings all say [object GridColumn]
            thanks
            • 3. Re: Spark DataGrid Help
              I'm really not sure, unless you can paste a simple 20+/- line example that I can try and play with.
              I can honestly say that this isn't something I personally have tried doing when testing the Spark DataGrid.
