0 Replies Latest reply on Dec 14, 2010 12:02 AM by luke3design!!
    Two remote objects calls on the same php class
    luke3design!! Level 1
      Hi to all,
             I've encountered a strange issue while developing with remote objects.
      I've a mxml component with an init() method inside which is called by a menu.
      When the init() method is called it makes 7 remote object calls which are bound to some components' dataprovider.
      Among this calls I've got 2 remote object which refer to the same remote class. This because I have to call the class twice and the bind the result to two different combobox. Below you find the code:
      <mx:RemoteObject id="myFile" source="myRemoteClass" destination="amfphp"  showBusyCursor="true" makeObjectsBindable="true" fault="traceFault(event)"/>
      <mx:RemoteObject id="myXls"  source="myRemoteClass" destination="amfphp"  showBusyCursor="true" makeObjectsBindable="true" fault="traceFault(event)"/>
      in the init function I make this calls:
      myFile.listDir("dir_1")
      myXls.listDir("dir_2")
      then in the mxml code I bound the result of myFile to combobox1 and the result of myXls on combobox2.
      The problem arise when I call the myXls' listDir method. When I call it I receive the following error:
      code:
      Client.Error.DeliveryInDoubt
      Message:
      Channel disconnected
      Detail:
      Channel disconnected before an acknowledgement was received
      The strange thing is that not only the myXls object returns this error, but also all the other 6 remote object return the same error above.
      I'm not sure, but I guess that the error could be caused by the two remote object which call the same php remote class. If I comment one of the two calls everything works fine.
      Do you have any suggestion about?
      Thanks!!
      Bye
      Luke
