7 Replies Latest reply on Dec 15, 2010 1:56 AM by danleech
    Error #1014: flash.events::StageVideoAvailabilityEvent
    danleech
      hello everyone!
      I hope, that name of the threas is correct.
      I use Flash builder 4, flash player 10.2.0... debug for other browsers(firefox), Flex SDK Hero 4.5.0.1....
      I make a AS3 project with simpleStageVideo from addobe issue about it.
      if delete lines with StageVideoAvailabilityEvent it works correctly and show my wideo. But when run all code, i have a debug error Error #1014: flash.events::StageVideoAvailabilityEvent can't find class.
      what is wrong??????????
      this is a code:
      package
          import flash.display.Bitmap;
          import flash.display.BitmapData;
          import flash.display.DisplayObject;
          import flash.display.Loader;
          import flash.display.Shape;
          import flash.display.Sprite;
          import flash.display.StageAlign;
          import flash.display.StageDisplayState;
          import flash.display.StageScaleMode;
          import flash.events.Event;
          import flash.events.FullScreenEvent;
          import flash.events.KeyboardEvent;
          import flash.events.MouseEvent;
          import flash.events.NetStatusEvent;
          import flash.events.StageVideoAvailabilityEvent;
          import flash.events.StageVideoEvent;
          import flash.events.TimerEvent;
          import flash.events.VideoEvent;
          import flash.geom.Rectangle;
          import flash.media.SoundTransform;
          import flash.media.StageVideo;
          import flash.media.StageVideoAvailability;
          import flash.media.Video;
          import flash.net.NetConnection;
          import flash.net.NetStream;
          import flash.system.LoaderContext;
          import flash.text.TextField;
          import flash.text.TextFieldAutoSize;
          import flash.text.TextFormat;
          import flash.ui.Keyboard;
           * @author Thibault Imbert
          [SWF(frameRate="1", backgroundColor="#000000")]
          public class CStageVideo extends Sprite
              private static const FILE_NAME:String = "C:/Users/Dan/Desktop/Goldenbird/render/Back30.flv";
              private static const INTERVAL:Number = 500;
              private static const BORDER:Number = 20;
              private var legend:TextField = new TextField();
              private var sv:StageVideo;
              private var nc:NetConnection;
              private var ns:NetStream;
              private var customClient:Object;
              private var duration: Number;
              private var rc:Rectangle;
              private var video:Video;
              private var thumb:Shape;
              private var interactiveThumb:Sprite;
              private var totalTime:Number;
              private var videoWidth:int;
              private var videoHeight:int;
              private var outputBuffer:String = new String();
              private var rect:Rectangle = new Rectangle(0, 0, 0, BORDER);
              private var videoRect:Rectangle = new Rectangle(0, 0, 0, 0);
              private var gotStage:Boolean;
              private var stageVideoInUse:Boolean;
              private var classicVideoInUse:Boolean;
              private var accelerationType:String;
              private var infos:String = new String();
              private var available:Boolean;
              private var inited:Boolean;
              private var played:Boolean;
              private var container:Sprite;
              public function CStageVideo()
                  // Make sure the app is visible and stage available
                  addEventListener(Event.ADDED_TO_STAGE, onAddedToStage);
               * @param event
              private function onAddedToStage(event:Event):void
                  // Scaling
                  stage.scaleMode = StageScaleMode.NO_SCALE;
                  stage.align = StageAlign.TOP_LEFT;
                  legend.autoSize = TextFieldAutoSize.LEFT;
                  // Debug infos
                  legend.multiline = true;
                  legend.background = true;
                  legend.backgroundColor = 0xFFFFFFFF;
                  addChild(legend);
                  // Thumb seek Bar
                  thumb = new Shape();
                  interactiveThumb = new Sprite();
                  interactiveThumb.addChild(thumb);
                  addChild(interactiveThumb);
                  // Connections
                  nc = new NetConnection();
                  nc.connect(null);
                  ns = new NetStream(nc);
                  ns.addEventListener(NetStatusEvent.NET_STATUS, onNetStatus);
                  //ns.client = this;
                  customClient = new Object;
                  customClient.onMetaData = metaDataHandler;
                  ns.client = customClient;
                  // Screen
                  video = new Video();
                  video.smoothing = true;
                  // Video Events
                  // the StageVideoEvent.STAGE_VIDEO_STATE informs you if StageVideo is available or not
                  stage.addEventListener(StageVideoAvailabilityEvent.STAGE_VIDEO_AVAILABILITY, onStageVideoState);
                  //toggleStageVideo(available = inited = false);
                  // in case of fallback to Video, we listen to the VideoEvent.RENDER_STATE event to handle resize properly and know about the acceleration mode running
                  video.addEventListener(VideoEvent.RENDER_STATE, videoStateChange);
                  // Input Events
                  stage.addEventListener(KeyboardEvent.KEY_DOWN, onKeyDown);
                  stage.addEventListener(Event.RESIZE,  onResize);
                  stage.addEventListener(MouseEvent.CLICK, onClick);
              private function metaDataHandler( meta:Object ):void
                  duration = meta.duration;
                  trace("meta duration -> " + duration);
               * @param event
              private function onNetStatus(event:NetStatusEvent):void
                  if ( event.info == "NetStream.Play.StreamNotFound" )
                      legend.text = "Video file passed, not available!";
               * @param event
              private function onFrame(event:Event):void
                  var ratio:Number = (ns.time / totalTime) * (stage.stageWidth - (BORDER << 1));
                  rect.width = ratio;
                  thumb.graphics.clear();
                  thumb.graphics.beginFill(0xFFFFFF);
                  thumb.graphics.drawRect(rect.x, rect.y, rect.width, rect.height);
               * @param event
              private function onClick(event:MouseEvent):void
                  if ( event.stageY >= interactiveThumb.y - BORDER && event.stageX <= stage.stageWidth - BORDER )
                      var seekTime:Number = (stage.mouseX - BORDER) * ( totalTime / (stage.stageWidth - (BORDER << 1) ) );
                      ns.seek( seekTime );
               * @param event
              private function onKeyDown(event:KeyboardEvent):void
                  if ( event.keyCode == Keyboard.O )
                      if ( available )
                          // We toggle the StageVideo on and off (fallback to Video and back to StageVideo)
                          toggleStageVideo(inited=!inited);
                  } else if ( event.keyCode == Keyboard.F )
                      stage.displayState = StageDisplayState.FULL_SCREEN;
                  } else if ( event.keyCode == Keyboard.SPACE )
                      ns.togglePause();
                  else if ( event.keyCode == Keyboard.DELETE )
                      played = false;
               * @param width
               * @param height
               * @return
              private function getVideoRect(width:uint, height:uint):Rectangle
                  var videoWidth:uint = width;
                  var videoHeight:uint = height;
                  var scaling:Number = Math.min ( stage.stageWidth / videoWidth, stage.stageHeight / videoHeight );
                  videoWidth *= scaling, videoHeight *= scaling;
                  var posX:uint = stage.stageWidth - videoWidth >> 1;
                  var posY:uint = stage.stageHeight - videoHeight >> 1;
                  videoRect.x = posX;
                  videoRect.y = posY;
                  videoRect.width = videoWidth;
                  videoRect.height = videoHeight;
                  return videoRect;
              private function resize ():void
                  if ( stageVideoInUse )
                      // Get the Viewport viewable rectangle
                      rc = getVideoRect(sv.videoWidth, sv.videoHeight);
                      // set the StageVideo size using the viewPort property
                      sv.viewPort = rc;
                  } else
                      rc = getVideoRect(video.videoWidth, video.videoHeight);
                      // Set the Video object size
                      video.width = rc.width;
                      video.height = rc.height;
                      video.x = rc.x, video.y = rc.y;
                  interactiveThumb.x = BORDER, interactiveThumb.y = stage.stageHeight - (BORDER << 1);
                  legend.text = infos;
               * @param evt
              public function onMetaData ( evt:Object ):void
                  totalTime = evt.duration;
                  stage.addEventListener(Event.ENTER_FRAME, onFrame);
               * @param event
              private function onStageVideoState(event:StageVideoAvailabilityEvent):void
                  // Detect if StageVideo is available and decide what to do in toggleStageVideo
                  toggleStageVideo(available = inited = (event.availability == StageVideoAvailability.AVAILABLE));
               * @param on
              private function toggleStageVideo(on:Boolean):void
                  infos = "StageVideo Running (Direct path) : " + on + "\n";
                  // If we choose StageVideo we attach the NetStream to StageVideo
                  if (on)
                      stageVideoInUse = true;
                      if ( sv == null )
                          sv = stage.stageVideos[0];
                          sv.addEventListener(StageVideoEvent.RENDER_STATE, stageVideoStateChange);
                      sv.attachNetStream(ns);
                      if (classicVideoInUse)
                          // If we use StageVideo, we just remove from the display list the Video object to avoid covering the StageVideo object (always in the background)
                          stage.removeChild ( video );
                          classicVideoInUse = false;
                  } else
                      // Otherwise we attach it to a Video object
                      if (stageVideoInUse)
                          stageVideoInUse = false;
                      classicVideoInUse = true;
                      video.attachNetStream(ns);
                      stage.addChildAt(video, 0);
                  if ( !played )
                      played = true;
                      ns.play(FILE_NAME);
               * @param event
              private function onResize(event:Event):void
                  resize();
               * @param event
              private function stageVideoStateChange(event:StageVideoEvent):void
                  infos += "StageVideoEvent received\n";
                  infos += "Render State : " + event.status + "\n";
                  resize();
               * @param event
              private function videoStateChange(event:VideoEvent):void
                  infos += "VideoEvent received\n";
                  resize();
