0 Replies Latest reply on Dec 14, 2010 1:35 PM by Cons1875
    flash skins and designers
    Cons1875 Level 1
      Hello,
      I'm primarily a Designer and I'm trying to  create multiple themes for a flex application. Each theme/look will be replaced every couple of months. It seems as though Flash (at least from a designers perspective)   is the best way to do that outside of flash Builder itself. In flash pro CS5, I've been using the flex template and changing each component there. I'm hoping that exporting a swc will be pretty seemles. I'd like to bring the new swc files in each time. Is this reasonable workflow for changing themes?
      I can use PS for example, but I'd like to avoid  bitmaps where I can. Can anyone suggest ways that they're working with designers to build UI's?
      I'm using CS5 on a mac.
