2 Replies Latest reply on Dec 15, 2010 7:22 AM by lesabredream
    CS5 and the slideshow template
      I just upgraded from Flash CS4 to CS5 and have discovered that the slide show template is no longer supported.
      Does anyone know if flash slideshows will be supported in upcoming versions of the Flash player or will they be discontinued?
        • 1. Re: CS5 and the slideshow template
          It bites, doesn't it?  I'm on CS4, but so many things have changed between each version it seems.  I think you can simply choose in your preferences to work with Actionscript 2 and an older version of Flash.  At least you can do that with CS4.  Surely you can with 5, too.  I'm sorry if this doesn't help, but that'd be my first thing to try and do.
          • 2. Re: CS5 and the slideshow template
            lesabredream Level 1
            Thanks for the ideas!
            When I try to open a CS4 fla containing a slideshow with CS5 it gives an error message "Slides and Forms documents are not supported in this version of Flash. Please open in a previous version."
            I called Adobe support and was told I would have to reauthor the slide show as a frame based app. After working for several years creating slide based flash presentations this is not good news.
            I guess my fear now is that if they dropped support for slides and forms in CS5 will they drop support for them in newer versions of Flash player as well. Yikes! That would sink me for sure.
