In HTML Options à Output folder and file name I was wondering if I can change the name of the .chm automatically listed when I click on properties?
For example when I click on properties for ABC_v456, which is an SSL in the ABC123 project, I see “C:\Projects\ABC_v123\!SSL!\Help_v456\ABC123.chm’ in the Output folder and File name field. I would like to rename ABC123.chm to ABC456.chm for clarities sake. When I compile will it then create a .chm file by the name of ABC456.chm rather than the ABC123.chm file name? I would then have the two SSLs in the HTML project called Help_v123 and Help_v456each and their respective .chm would be within each folder. Am I talking sense or is this gibberish requiring clarification on my part? I am using Robohelp HTML v7.
Hi Renita
You should be able to freely name the CHM whatever makes sense to you in the field.
I recall you are also possibly involved in CSH development. So the file name could play a significant role in that. But even after you generate the help you should be able to rename it if you want.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 moments from now - $24.95! |
Hi Renita
Cheers... Rick
