1. Re: search for clips on timeline
Colin Brougham Dec 15, 2010 11:05 AM (in response to lou4uandme)First, search for it in the Project Panel. When it's revealed, click on it, then go up to the information display at the top of the Project Panel. In the line of info just under the clip name, you'll see a small downward pointing triangle; if you click that, it will reveal a list of sequences and timecodes where the clip is in use. Selecting one of those will bring the sequence forward and park the CTI at that point.
2. Re: search for clips on timeline
Bill Hunt Dec 15, 2010 11:20 AM (in response to lou4uandme)Lou,
After you have located that Plunger Audio file in the Project, per Colin's directions, you might want to look to see the format of that. Sounds like it could be an SFX file, just by the name. If that Asset is an MP3 (some other formats can be problematic too), you might want to Delete it from the Project (make note of where it was used in the Sequences first), and convert it to PCM/WAV 48KHz 16-bit. That might end the Conforming errors. Audition, Soundbooth, or other, like the free Audacity, can do that conversion for you. Import the WAV file into the Project and just place it in the location(s) shown in your search.
3. Re: search for clips on timeline
lou4uandme Dec 15, 2010 12:00 PM (in response to Bill Hunt)Hi Guys,
Ok, first, I never knew that little triangle was even there! I love it.
The only problem ,like I said, was that it doesn't show up in the search.
Go figure. Is there any other way to locate this file?
I will try the other suggestions now...BRB
4. Re: search for clips on timeline
Bill Hunt Dec 15, 2010 12:08 PM (in response to lou4uandme)Out of curiosity, does "Plunger" show up anywhere in your Project Panel? That location will depend on how you organize your Bins, so you might need to open up a lot of them, looking for "Plunger___."
As for the CFA file, that should be in your Media Cache folder (located by user, or by default within the Scratch Disk settings), along with a similarly named PEK file. Now, that is only for the CFA and PEK, and does not show you where it's used in a Project. Those will have been created from the actual Audio file, located elsewhere on your system, and with the WAV, MP3, etc. file extension. Again, that does not tell you where it's used.
Do not know if it will help in the long run, but if you find and Delete the CFA and PEK, then PrPro will regenerate them, when you Open that Project. Perhaps Conforming will go more smoothly the second time around? Be sure to allow the Conforming to complete, before doing anything else. There is a small progress bar at the lower-right of the GUI.
5. Re: search for clips on timeline
Colin Brougham Dec 15, 2010 12:16 PM (in response to lou4uandme)Do you have any Dynamic Linked AE comps in your project?
6. Re: search for clips on timeline
lou4uandme Dec 15, 2010 3:26 PM (in response to Colin Brougham)Hi Again,
Ok, I'm in loop Hell. I made a copy of the project. I then started to delete files one by one.
I now have deleted EVERY FILE. As soon as I minimize the program and then open it, it starts comforming the error message again.
I am at a lost for words at this point.
7. Re: search for clips on timeline
Colin Brougham Dec 15, 2010 5:25 PM (in response to lou4uandme)Can you zip up and upload your project file somewhere? Don't need any media--just the PRPROJ file. You can also email it to me; shoot me a PM and I'll contact you.
