0 Replies Latest reply on Dec 15, 2010 11:23 AM by goirish34
    File upload - select existing image or upload a new image option when adding a new entry
    goirish34
      Any  ideas on how I can build a function that allows me to select an  existing image stored in a folder to update an entry on a database  driven page?  Below is an edit page and the related update page.  See  how I handle the image being pulled out of the database.  This works fine when I am changing the page and either uploading a new image or not changing the image.  Whenever I add  an entry or edit an entry, I would like to be able to either upload a  new image, or grab an existing image in a specified folder.  Thoughts?
      Page 1
      <!--- Entry form --->
      <br>
      Thumbnail images should be sized at 140 x 140 pixels at 72 dpi<br>
      Full size images should be sized at 475 pixels wide x 200-250 pixels height at 72 dpi
      <br>
      <br>
      <cfoutput query="getinfo">
      <CFFORM action="editpost2.cfm" name="miscellaneous" method="post" enctype="multipart/form-data">
      <input type="hidden" name="ID" value="#ID#">
      <TABLE>
          <TR>
          <TD valign="top"> Post Department </TD>
          <TD>
      <select name="Department_ID">
      <cfoutput>
      <cfloop query="getdepartments2"><option value="#ID#">#Title#</option></cfloop>
      <cfloop query="getdepartments"><option value="#ID#">#Title#</option></cfloop>
      </cfoutput>
      </select>
                     </TD>
                     </TR>
              <TR>
          <TD valign="top"> Post Categories </TD>
          <TD>
      <cfoutput>
      <cfloop  query="getstuff"><input name="Category_ID" type="checkbox"  value="#getstuff.B#" <cfif  ListFind(roleList,getstuff.B)>checked</cfif>>#getstuff.D#<br></cfloop>
      </cfoutput>
                     </TD>
                     </TR
          ><TR>
          <TD valign="top"> Title </TD>
          <TD>
                                    <INPUT type="text" name="title" value="#Title#" size="60" maxLength="100">
                     </TD>
                     </TR>
          <TR>
          <TD valign="top"> Subtitle </TD>
          <TD>
                                    <INPUT type="text" name="Subtitle" value="#Subtitle#" size="60" maxLength="100">
                     </TD>
                     </TR>
      <tr>
      <td valign="top">Thumbnail</td>
      <td valign="top">
      <input type="file" name="Image" value="" size="50">
      <input type="hidden" name="oldimage" value="#getinfo.Image#">
      <cfif getinfo.image is not "">
      <br><b><a  href="../sharedimages/#getinfo.Image#" target="_blank"  style="text-decoration: underline; color: ##63bded; font-weight:  600;">[View #getinfo.Image#]</a></b><br><br>
      </cfif>
      </td>
      </tr>
          <TR>
          <TD valign="top"> Photo Credit </TD>
          <TD>
                                    <INPUT type="text" name="PhotoCredit" value="#PhotoCredit#" size="60" maxLength="100">
                     </TD>
                     </TR>
      <tr>
      <td valign="top">Image</td>
      <td valign="top">
      <input type="file" name="Image2" value="" size="50">
      <input type="hidden" name="oldimage2" value="#getinfo.Image2#">
      <cfif getinfo.image2 is not "">
      <br><b><a  href="../sharedimages/#getinfo.Image2#" target="_blank"  style="text-decoration: underline; color: ##63bded; font-weight:  600;">[View #getinfo.Image2#]</a></b><br><br>
      </cfif>
      </td>
      </tr>
          <TR>
          <TD valign="top"> Photo Credit2 </TD>
          <TD>
                                    <INPUT type="text" name="PhotoCredit2" value="#PhotoCredit2#" size="60" maxLength="100">
                     </TD>
                     </TR>
          <TR>
          <TD valign="top"> Description </TD>
          <TD>
                      <cftextarea width="800" height="250" name="Description"  richtext="yes" enabled="yes">#Description#</cftextarea>
                     </TD>
                     </TR>
          <TR>
          <TD valign="top"> Description2 </TD>
          <TD>
                      <cftextarea width="800" height="250" name="Description2"  richtext="yes" enabled="yes">#Description2#</cftextarea>
                     </TD>
                     </TR>
                     <TR>
          <TD valign="top"> Download Link </TD>
          <TD>
                                     <INPUT type="text" name="DownloadLink" value="#DownloadLink#"  size="40" maxLength="100"><br> (example:  http://www.cnn.com/test.pdf)
                     </TD>
                     </TR>
      <tr>
      <td>Active Date</td>
      <td><cfinput type="datefield" name="Active_DT" value="#DateFormat(Active_DT,"mm/dd/yyyy")#"></td>
      </tr>
      <tr>
      <td>Expiration Date</td>
      <td><cfinput type="datefield" name="Expiration_DT" value="#DateFormat(Expiration_DT,"mm/dd/yyyy")#"></td>
      </tr>
          <TR>
          <TD valign="top"> Active </TD>
          <TD>
        <select name="Active">
                     <option value="#Active#">#Active#</option>
                     <option value="Yes">Yes</option>
                     <option value="No">No</option>
      </select>
                     </TD>
                     </TR>
          <TR>
          <TD valign="top"> Approved </TD>
          <TD>
        <select name="Approved">
                     <option value="#Approved#">#Approved#</option>
      </select>
                     </TD>
                     </TR>
                     <TR>
          <TD valign="top"> Display Order </TD>
          <TD>
                                    <INPUT type="text" name="DisplayOrder" value="#DisplayOrder#" size="5" maxLength="5">
                     </TD>
                     </TR>
      </TABLE>
      <P>
      <input type="submit" value="Edit Post">
      </CFFORM>
      Page 2
      <cfinclude template="adminsecurityheader.cfm">
      <cfif FORM.Image neq "">
      <!--- first actually upload the file --->
      <cffile ACTION="UPLOAD"
              FILEFIELD="Image"
              DESTINATION="#ImagesUpload#"
                                    NAMECONFLICT="OVERWRITE">
      <cfset Image = #cffile.serverFileName# & "." & #cffile.serverFileExt#>
      <!--- delete old file if the name is not the same --->
      <cfif #oldimage# NEQ "">
      <cfif #Image# NEQ #oldimage#>
      <cfif FileExists("#ImagesUpload#\#oldimage#")>
      <cffile ACTION="DELETE" FILE="#ImagesUpload#\#oldimage#">
      </cfif>
      </cfif>
      </cfif>
      <cfelse>
      <cfset Image = "#oldimage#">
      </cfif>
      <cfif FORM.Image2 neq "">
              FILEFIELD="Image2"
      <cfset Image2 = #cffile.serverFileName# & "." & #cffile.serverFileExt#>
      <cfif #oldimage2# NEQ "">
      <cfif #Image2# NEQ #oldimage2#>
      <cfif FileExists("#ImagesUpload#\#oldimage2#")>
      <cffile ACTION="DELETE" FILE="#ImagesUpload#\#oldimage2#">
      </cfif>
      </cfif>
      </cfif>
      <cfelse>
      <cfset Image2 = "#oldimage2#">
      </cfif>
      <cfparam name="Category_ID" default="0">
      <cflock timeout="20" throwontimeout="No" name="#CreateUUID()#">
      <cftransaction>
      <cfquery  name="getinfo" datasource="#Application.DS#"  username="#Application.DSusername#" password="#Application.DSpassword#"  dbtype="ODBC">
      UPDATE Posts SET
      Department_ID = <cfqueryparam cfsqltype="CF_SQL_INTEGER" maxlength="5" value="#Department_ID#">,
      Title = <cfqueryparam cfsqltype="CF_SQL_VARCHAR" maxlength="150" value="#Title#">,
      Subtitle = <cfqueryparam cfsqltype="CF_SQL_VARCHAR" maxlength="150" value="#Subtitle#">,
      Image = <cfqueryparam cfsqltype="CF_SQL_VARCHAR" maxlength="150" value="#Image#">,
      PhotoCredit = <cfqueryparam cfsqltype="CF_SQL_VARCHAR" maxlength="150" value="#PhotoCredit#">,
      Image2 = <cfqueryparam cfsqltype="CF_SQL_VARCHAR" maxlength="150" value="#Image2#">,
      PhotoCredit2 = <cfqueryparam cfsqltype="CF_SQL_VARCHAR" maxlength="150" value="#PhotoCredit2#">,
      Description = <cfqueryparam cfsqltype="CF_SQL_LONGVARCHAR" value="#Description#">,
      Description2 = <cfqueryparam cfsqltype="CF_SQL_LONGVARCHAR" value="#Description2#">,
      DownloadLink = <cfqueryparam cfsqltype="CF_SQL_VARCHAR" maxlength="150" value="#DownloadLink#">,
      Active = <cfqueryparam cfsqltype="CF_SQL_VARCHAR" maxlength="10" value="#Active#">,
      Approved = <cfqueryparam cfsqltype="CF_SQL_VARCHAR" maxlength="10" value="#Approved#">,
      DisplayOrder = <cfqueryparam cfsqltype="CF_SQL_VARCHAR" maxlength="100" value="#DisplayOrder#">,
      Active_DT = <cfqueryparam cfsqltype="CF_SQL_VARCHAR" maxlength="100" value="#Active_DT#">,
      Expiration_DT = <cfqueryparam cfsqltype="CF_SQL_VARCHAR" maxlength="100" value="#Expiration_DT#">
      WHERE ID = <cfqueryparam cfsqltype="CF_SQL_INTEGER" maxlength="5" value="#ID#">
      </cfquery>
      <cfquery  name="del_roles" datasource="#Application.DS#"  username="#Application.DSusername#" password="#Application.DSpassword#"  dbtype="ODBC">
                     delete from PostCats where Post_ID = <cfqueryparam cfsqltype="CF_SQL_INTEGER" maxlength="5" value="#ID#">
      </cfquery>
      <!--- now lets insert the roles --->
      <cfloop list="#Category_ID#" index="idx">
                      <cfquery name="ins_roles" datasource="#Application.DS#"  username="#Application.DSusername#" password="#Application.DSpassword#"  dbtype="ODBC">
                                    insert into PostCats
                                                   (Post_ID, Category_ID)
                                    values
                                                    (<cfqueryparam cfsqltype="CF_SQL_INTEGER" maxlength="5"  value="#ID#">,#val(idx)#)
                     </cfquery>
      </cfloop>
      </cftransaction>
      </cflock>
