2 Replies Latest reply on Dec 15, 2010 12:17 PM by teamhood
    Proper work flow before multiclip? Crop, Resize, Edit?
    teamhood
      Hey all,
      I have quick question as to what is the proper work flow that I should follow? I have 4 camera angles synced up with an external audio source in Sequence 'Sync'. Now should I go through and make any crop and resize adjustment to all of the clips/angles and then render before I start to multiclip in the nested sequence? Or can I just go and cut and then make adjustments to the orginal tracks and would it then update all the cuts in the nested sequence?
      Thank you for the help!
