1 Reply Latest reply on Dec 15, 2010 12:56 PM by MYX
    Pops and or snaps when touching the effects rack during playback
    MYX Level 1
      Hey Auditioneers,
      I am working on a mix and today I notices that when I left the mixer and started to click on the effects rack to add more effects, I started to hear popping. This was before an actual effect was selected. This also happens if I have effects turned off and then I turn them on while playing.
      The project stems from a FCP Project. I have 2 voice tracks and 2 music tracks. The 2 music tracks are subbed down to "Music Bus".
      Effects in use... Multiband Comp, Parametric EQ, and Tube-modeled Comp.
      Both voice tracks have the same effects.
      Lastly I have a tube modeled comp on the master.
        • 1. Re: Pops and or snaps when touching the effects rack during playback
          MYX Level 1
          Update. This also happens in the mixer and effects.
          While it seemed intermittent earlier, the pops seems to happen over edit points (where the audio is split). I have used the handles to assure that there is no overhanging audio at the slipt point. I can play through it over and over without issue. When I am making adjustments to the mixer, effects... and I cross an edit, then the likelyhood goes up substantially. But it is not consistent. Sometimes it happens sometimes it does not.
