1 Reply Latest reply on Dec 16, 2010 5:20 AM by Jasmin Charbonneau
    Renaming generated files
    Marcos J Pinto Level 1
      I've created a very simple process in Workbench using Output to merge XLM and XDP files and generate PDFs.
      Everything is woking fine, but as I get dozens of XML and generate the same number of PDF files.
      I'm using WriteDocument service operation from FileUtilsService (Foundation) to save the files and I marked the Append a suffix to the file name to make it unique if it has been used option.
      It works, but the suffixes appended to the file names are random numbers.
      I need to name the files in sequence - how do I do it? Do I have to add any other block to this process?
      Thank you for any hints!
