0 Replies Latest reply on Dec 17, 2010 5:50 AM by Marcos J Pinto
    XML-XDP Merging - Some files are dropped - how to fix it?
    Marcos J Pinto Level 1
      Hello!
      I've created a very simple process in Workbench using Output to merge XLM and XDP files and generate PDFs.
      The XML files are dropped in a watched folder and each file has 10,000 lines.
      If I drop just one XML file the process will run smoothly and create the PDF accordingly.
      However, if I drop, say, 12 files in the folder, only 3 or 4 files are processed and the others are dropped. In the error log I get this:
      Failure Time----Fri Dec 17 11:32:07 BRST 2010
      source location ---- Reason of failure is-----Internal error.
      Internal error.
      [com.arjuna.ats.internal.jta.transaction.arjunacore.inactive] [com.arjuna.ats.internal.jta.transaction.arjunacore.inactive] The transaction is not active!
      ALC-DSC-000-000: com.adobe.idp.dsc.DSCRuntimeException: Internal error.
      Is there a way of solving this?
      When the process was running I checked the CPU and RAM usage in Task Manager and realized they were both at 100% most of the time.
      Is there a way of avoiding this problem?
      I'm running this on a Core2 Duo with 4 GB RAM.
      Thank you for any ideas!
      Marcos
