7 Replies Latest reply on Dec 18, 2010 6:18 AM by saisri2k2
    TypeError: Error #1034: Type Coercion failed: cannot convert mx.utils::ObjectProxy@ad73f7c1 to Array
    Whitetimer Level 1
      Hi All
      I am trying to code a shop front and i keep getting this error message
      TypeError: Error #1034: Type Coercion failed: cannot convert mx.utils::ObjectProxy@ad73f7c1 to Array.
      This is the code i have
      <!-- Declarations ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -->
          <fx:Declarations>
              <fx:Model id="shopDataModel" source="../../Data/XML/shopdata.xml"/>
              <s:ArrayCollection id="shopDataArray" source="{shopDataModel.shopitem}"/>
          </fx:Declarations>
          <!-- Metadata ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -->
          <!-- Styles ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -->
          <!-- Script ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -->
          <fx:Script>
              <![CDATA[
              // import statements ----------------------------------------
              import VO.ShopItem;
              import mx.collections.ArrayCollection;
              import flash.net.URLLoader;
              import flash.net.URLRequest;
              import mx.managers.CursorManager;
              // constant declarations ------------------------------------
              // variable declarations ------------------------------------
              [Bindable]
              public var shopItems:ShopItem = new ShopItem();
              // getter/setters -------------------------------------------
              // helper methods -------------------------------------------
              // event handlers -------------------------------------------
              protected function loadShopData():void {
                  for (var i:int = 0; i < shopDataArray.length; i++)
                      var shopItemObj:Object = shopDataArray.getItemAt(i);
                      var shopItemVO:ShopItem = new ShopItem();
                      shopItemVO.category = shopItemObj.category;
                      shopItemVO.id = int(shopItemObj.id);
                      shopItemVO.name = shopItemObj.name;
                      shopItemVO.information = shopItemObj.information;
                      shopItemVO.image = shopItemObj.image;
                      shopItemVO.price = Number(shopItemObj.price);
                      shopDataArray.setItemAt(shopItemVO, i);
      Any suggestions please ?
      many Thanks
        • 1. Re: TypeError: Error #1034: Type Coercion failed: cannot convert mx.utils::ObjectProxy@ad73f7c1 to Array
          Flex harUI Adobe Employee
          Could be the array of one issue.  Search past thread on ArrayUtil and on my
          blog
          Alex Harui
          Flex SDK Team
          Adobe System, Inc.
          http://blogs.adobe.com/aharui
          • 2. Re: TypeError: Error #1034: Type Coercion failed: cannot convert mx.utils::ObjectProxy@ad73f7c1 to Array
            Whitetimer Level 1
            Thanks for the reply, but still having problems sorting this error out ......
            • 3. Re: TypeError: Error #1034: Type Coercion failed: cannot convert mx.utils::ObjectProxy@ad73f7c1 to Array
              saisri2k2 Level 4
              in the above line confirm that the shopDataModel.shopitem is not an arrayCollection, looks like shopitem is an simpleobject
              • 4. Re: TypeError: Error #1034: Type Coercion failed: cannot convert mx.utils::ObjectProxy@ad73f7c1 to Array
                Whitetimer Level 1
                It should have been an ArrayList and now it works.  But now i am having trouble passing the data to a custom dataGrid Component ...
                <?xml version="1.0"?>
                <s:Group
                        xmlns:fx="http://ns.adobe.com/mxml/2009"
                        xmlns:mx="library://ns.adobe.com/flex/mx"
                        xmlns:comp='ShoppingCart.Components.*'
                        width="900" height="100%">
                    <!-- Properties of the parent ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -->
                    <s:layout>
                        <s:HorizontalLayout />
                    </s:layout>
                    <fx:Declarations>
                        <fx:Model id="shopDataModel" source="../Data/XML/shopdata.xml" />
                        <s:ArrayList id="shopDataArray" source="{shopDataModel.shopitem}" />
                    </fx:Declarations>
                    <fx:Script>
                        <![CDATA[
                        import ShoppingCart.VO.ShopItemVO;
                        [Bindable]
                        public var shopItems:ShopItemVO = new ShopItemVO();
                                var shopItemVO:ShopItemVO = new ShopItemVO();
                                shopItemVO.description = shopItemObj.description;
                    </fx:Script>
                    <!-- States ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -->
                    <s:states>
                        <s:State id="shopGridView" name="shopGridView" />
                        <s:State id="shopTileView" name="shopTileView" />
                    </s:states>
                    <!-- UI components ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -->
                    <comp:CompShopDataGrid id="compShopDataGrid" excludeFrom="shopTileView" dataProvider="{shopDataArray}" />
                    <comp:CompShopTileList id="compShopTileList" excludeFrom="shopGridView"/>
                    <comp:CompShoppingCart id="compShoppingCart" />
                And my Custom DataGrid looks like this
                <mx:DataGrid
                        width="100%">
                    <fx:Declarations>
                        <!-- Place non-visual elements (e.g., services, value objects) here -->
                    </fx:Declarations>
                    <fx:Script>
                        <![CDATA[
                    </fx:Script>
                    <mx:columns>
                        <mx:DataGridColumn width="100" headerText="Item ID #" dataField="{data.id}" />
                        <mx:DataGridColumn headerText="Item Name" dataField="{data.name}" />
                        <mx:DataGridColumn width="100" headerText="Item Price £" dataField="{data.price}" />
                    </mx:columns>
                </mx:DataGrid>
                Many Thanks
                • 6. Re: TypeError: Error #1034: Type Coercion failed: cannot convert mx.utils::ObjectProxy@ad73f7c1 to Array
                  Whitetimer Level 1
                  No i dont get an error now.  But the data is not appearing in the Custom DataGrid.
                  • 7. Re: TypeError: Error #1034: Type Coercion failed: cannot convert mx.utils::ObjectProxy@ad73f7c1 to Array
                    saisri2k2 Level 4
                    looks like your arraylist is not bindable,
                    or t the end of the for loop, do
                    dataGrid.dataprovider = arrayListId;
                    datagrid.invalidateList();
                    If this answer helped you, Please mark it as such.
