7 Replies Latest reply: Dec 23, 2010 9:42 PM by sourabhgoel RSS
    "error loading updater workflow"...trying to install camera raw 6.3 plug in
    captain1944 Community Member
      A very helpful response to an earlier question got me to realize the need to instll the latest raw plugin....6.3....
      Now when I go to install I get "error loading updating workflow"
      any help on this one???
      I have CS5  using windows 7 on my dell inspiiron 1545 pc......this was an update t cs5 from previously installed cs4
      version
        • 1. Re: "error loading updater workflow"...trying to install camera raw 6.3 plug in
          sourabhgoel Community Member
          Please provide these logs:
          1. PDApp.log (present in the folder : <Users folder>\AppData\Local\Temp)
          2. aamu.log (present in the folder : <Users folder>\Appdata\Local\Adobe\AAMUpdater\1.0)
          Please mail these logs to sgoel@adobe.com
          Sourabh
          • 2. Re: "error loading updater workflow"...trying to install camera raw 6.3 plug in
            thanks but do not know how to locate these....
            • 3. Re: "error loading updater workflow"...trying to install camera raw 6.3 plug in
              Press <windows> button + "R" key and you will get a run prompt. There type "%TEMP%" and press enter. This will take you to the TEMP folder.
              Here you locate PDApp.log.
              Go up one folder and you can find the Local folder there. Inside the Local folder, go to Adobe\AAMUpdater\1.0. Here you should see aamu.log
              • 4. Re: "error loading updater workflow"...trying to install camera raw 6.3 plug in
                not sure if this is right but this was in the PDnotepad?
                12/21/2010 03:00:24 AAMUpdatesNotifier - Build Version - 1.0.175.0
                12/21/2010 03:00:24 AAMUpdatesNotifier - Logging Level verbosity Set
                to 4
                12/21/2010 03:00:27 Utilities - File does not exist
                12/21/2010 03:00:41 AAMUpdatesNotifier - CFU .... StatusCode(41)
                ErrorCode(212)
                12/21/2010 03:00:41 AAMUpdatesNotifier - inside getUpdates
                12/21/2010 03:00:41 AAMUpdatesNotifier - Cannot find any update Node
                12/21/2010 03:00:41 AAMUpdatesNotifier - All updates count 0
                this was in the folder one uP???
                Catalyst execution began: 12/20/2010 14:02:03.
                Loaded Dll : C:\Users\joan\AppData\Local\Temp\Setup00000a24\OSETUP.DLL.
                Catalyst version is : 14.0.4755.1000
                JobExecutionMode is CollectUserInfoExecutionMode.
                The UI level has been set to: Full
                Configuring Product: {90140000-003D-0000-0000-0000000FF1CE}
                Loading ARP entry.
                LIS: start parsing setup xml
                LIS: finished parsing LIS package "{90140000-0019-0409-0000-0000000FF1CE}"
                LIS: finished parsing LIS package "{90140000-0016-0409-0000-0000000FF1CE}"
                LIS: finished parsing LIS package "{90140000-0115-0409-0000-0000000FF1CE}"
                LIS: finished parsing LIS package "{90140000-002C-0409-0000-0000000FF1CE}"
                LIS: finished parsing LIS package "{90140000-00A1-0409-0000-0000000FF1CE}"
                LIS: finished parsing LIS package "{90140000-001A-0409-0000-0000000FF1CE}"
                LIS: finished parsing LIS package "{90140000-0117-0409-0000-0000000FF1CE}"
                LIS: finished parsing LIS package "{90140000-003D-0000-0000-0000000FF1CE}"
                LIS: finished parsing LIS package "{90140000-0116-0409-1000-0000000FF1CE}"
                LIS: finished parsing LIS package "{90140000-001B-0409-0000-0000000FF1CE}"
                LIS: finished parsing LIS package "{90140000-0018-0409-0000-0000000FF1CE}"
                Product: SINGLEIMAGE
                  AddOnGroup Culture: en-us
                    AddOnId: WORD.EN-US
                    AddOnId: OFFICE.EN-US
                    AddOnId: PUBLISHER.EN-US
                    AddOnId: ACCESS.EN-US
                    AddOnId: ONENOTE.EN-US
                    AddOnId: PROOFING.EN-US
                    AddOnId: OFFICE64.EN-US
                    AddOnId: OUTLOOK.EN-US
                    AddOnId: EXCEL.EN-US
                    AddOnId: POWERPOINT.EN-US
                • 5. Re: "error loading updater workflow"...trying to install camera raw 6.3 plug in
                  The PDApp.log file seems correct. But I will need the complete file in order to look into the issue.
                  Please follow these steps.
                  1. Rename PDApp.log file to some other name
                  2. Try to apply the patch again.
                  3. If you still face the same issue, then go to the %TEMP% folder and copy the newly created PDApp.log file from there.
                  Please send the log file to sgoel@adobe.com
                  There should be a folder by the name "Adobe" along with folder TEMP. aamu.log is present in "Adobe\AAMUpdater\1.0" folder. Please see if you can locate this log file as well.
                  Sourabh
                  • 6. Re: "error loading updater workflow"...trying to install camera raw 6.3 plug in
                    "PDA file "and "changed PDA file...."
                    PDA file
                    12/21/2010 11:35:13 PDApp - Build Version - 1.0.175.0
                    12/21/2010 11:35:13 PDApp - Logging Level verbosity Set  to 4
                    12/21/2010 11:35:13 PDApp.CommandLineParser - Parsing the command
                    line provided. Number of command line arguments is 6
                    12/21/2010 11:35:13 PDApp - DWA AppletID argument not specified on
                    command line. Trying to find the existing instance
                    12/21/2010 11:35:13 PDApp - This is the first instance so creating a
                    thread for listening to the created pipe
                    12/21/2010 11:35:13 PipeThread - Pipe thread started
                    12/21/2010 11:35:13 PDApp - Starting AsyncMessageProcessor
                    12/21/2010 11:35:13 PDApp.AsyncMsgProcessor - AsyncMsgProcessor
                    initialized...
                    started. on thread id = 4960
                    12/21/2010 11:35:13 PDApp - Detecting Applet Database Library file...
                    12/21/2010 11:35:13 PDApp - Fetching Applet registeration
                    information...
                    12/21/2010 11:35:13 PDApp.AppletManager - AppletManager initialize...
                    12/21/2010 11:35:13 PIM - Build Version - 1.0.175.0
                    12/21/2010 11:35:13 PIM - Logging Level verbosity Set  to 4
                    12/21/2010 11:35:13 PIM - CREATE PIM Instance ...
                    12/21/2010 11:35:13 Utilities - File does not exist
                    12/21/2010 11:35:13 PIM - trying to createOrUpdatePIMDbSchema.
                    12/21/2010 11:35:13 PIM - Current db schema version on machine 1.
                    12/21/2010 11:35:13 PIM - Current db schema version to install 1.
                    12/21/2010 11:35:13 PIM - PIM DB Schema is up to date. Current schema
                    version is 1.
                    12/21/2010 11:35:13 PIM - PIM Database is Up To Date.
                    12/21/2010 11:35:13 PIM - PIMSqlite closeDB status 0
                    12/21/2010 11:35:13 PIM - FREE PIM Instance ...
                    12/21/2010 11:35:13 PDApp.AppletManager - Applet database path -
                    C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core\..
                    12/21/2010 11:35:13 PDApp.AppletManager - PIM library path -
                    C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core\AdobePIM.dll
                    12/21/2010 11:35:13 PDApp.AppletManager - Loading PIM library...
                    12/21/2010 11:35:13 PDApp.AppletManager - Getting applet data from
                    Applet database
                    12/21/2010 11:35:13 PDApp.AppletManager - All installed pakages
                    version string (pim_getCurrentPackagesVersion) is
                    DWA:1.0.172.0|LWA:1.0.175.0|PDApp:1.0.175.0|UWA:1.0.175.0
                    12/21/2010 11:35:13 PDApp.AppletManager - Registering Applets...
                    12/21/2010 11:35:13 PDApp.WindowManager - Initializing native
                    WindowManager
                    12/21/2010 11:35:13 PDApp.WindowManager - Creating window instance
                    12/21/2010 11:35:13 PDApp.WindowManager - Checking for appletID and
                    appletVersion given in CommandLineOptions
                    12/21/2010 11:35:13 PDApp.WindowManager - Creating APE stage instance
                    12/21/2010 11:35:15 PDApp.ExternalGateway - MessageHandler
                    initialized...
                    12/21/2010 11:35:15 PDApp.ExternalGateway - ExternalGateway
                    initialized...
                    12/21/2010 11:35:15 PDApp.ExternalGateway - NativeCommandHandler
                    initialized...
                    12/21/2010 11:35:15.431 PDApp.StartupCommand Logging Level verbosity
                    Set to  INFO
                    12/21/2010 11:35:15.432 PDApp.StartupCommand Processing the startup
                    Command
                    12/21/2010 11:35:15.439 PDAPP.AppletManager Starting Applet
                    registeration...
                    12/21/2010 11:35:15.457 PDAPP.MainDisplayMediator Looking up for the
                    Exact versioned applet for ID :UWA_UI
                    12/21/2010 11:35:15.479 PDAPP.AppletManager Loading Applet: UWA_UI
                    Version = 1.0
                    12/21/2010 11:35:15.514 PDApp.ZStringLoader PDAPP SWF - locale set
                    to - en_US
                    12/21/2010 11:35:15.570 PDAPP.AppletManager Loading progress0 out of
                    521002
                    12/21/2010 11:35:15.572 PDAPP.AppletManager Loading progress65536 out
                    of 521002
                    12/21/2010 11:35:15.574 PDAPP.AppletManager Loading progress131072
                    out of 521002
                    12/21/2010 11:35:15.583 PDAPP.AppletManager Loading progress196608
                    out of 521002
                    12/21/2010 11:35:15.585 PDAPP.AppletManager Loading progress262144
                    out of 521002
                    12/21/2010 11:35:15.588 PDAPP.AppletManager Loading progress327680
                    out of 521002
                    12/21/2010 11:35:15.590 PDAPP.AppletManager Loading progress393216
                    out of 521002
                    12/21/2010 11:35:15.592 PDAPP.AppletManager Loading progress458752
                    out of 521002
                    12/21/2010 11:35:15.594 PDAPP.AppletManager Loading progress521002
                    out of 521002
                    12/21/2010 11:35:16.023 PDApp.ExternalGateway Recieved Applet Loading
                    Completion
                    12/21/2010 11:35:16.027 UWA.ZStringLoader Trying to load ZString for
                    preferred locale - en_US
                    12/21/2010 11:35:16.087 UWA.ZStringLoader Applet locale set to -
                    en_US
                    12/21/2010 11:35:16.319 UWAApplet.Startup Processing the startup
                    command
                    12/21/2010 11:35:16.324 UWA.LoadWorkflowCommand Processing the
                    LoadWorkflowCommand
                    12/21/2010 11:35:16 PDApp.AppletManager - Loading Applet - UWA_Native
                    for WindowID - 1
                    12/21/2010 11:35:16 UWANative - Build Version - 1.0.175.0
                    12/21/2010 11:35:16 UWANative - Logging Level verbosity Set  to 4
                    12/21/2010 11:35:16 UWANative - Updater in patch mode
                    12/21/2010 11:35:16 UWANative - Error in mdbOpenSessionNoCreate 1
                    12/21/2010 11:35:16 UWANative - Failed to initialize Updater Core
                    12/21/2010 11:35:20 Utilities - Directory not present
                    12/21/2010 11:35:20 UWANative - Could not delete the temp folder "".
                    12/21/2010 11:35:16.594 UWA.LoadWorkflowCommand The start applet did
                    not return the result xml. Startapplet returned
                    12/21/2010 11:35:16.595 UWA.LoadWorkflowCommand Cannot start
                    UWANative Applet
                    12/21/2010 11:35:20 PDApp.AppletManager - Un-loading Applet -
                    UWA_Native for window ID - 1
                    12/21/2010 11:35:20 PDApp.ExternalGateway - Callng the finalize
                    function of the applet
                    12/21/2010 11:35:20 PDApp.ExternalGateway - Unloading applet
                    12/21/2010 11:35:20.878 PDApp.HostMessageHandler Recieved force
                    window close message
                    12/21/2010 11:35:20.878 PDApp.HostMessageHandler Sending message to
                    native
                    12/21/2010 11:35:20 PDApp.WindowManager - Window destruction reached
                    for ID - 1
                    12/21/2010 11:35:21 PipeThread - Pipe Connected. Waiting for data to
                    come on pipe
                    12/21/2010 11:35:21 PipeThread - 2 bytes read on pipe
                    12/21/2010 11:35:21 PipeThread - Data recieved on pipe. Sending the
                    data to the main thread to process and show window
                    12/21/2010 11:35:21 PipeThread - Message Sent to main thread
                    12/21/2010 11:35:21 PipeThread - Disconnecting pipe
                    12/21/2010 11:35:21 PipeThread - Pipe Disconnected
                    12/21/2010 11:35:21 PipeThread - Terminating the pipe thread
                    12/21/2010 11:35:21 PDApp - Terminating native MessageQueueManager
                    12/21/2010 11:35:21 PDApp - Terminating native AppletManager
                    12/21/2010 11:35:21 PDApp.AppletManager - AppletManager destructed
                    12/21/2010 11:35:21 PDApp - Terminating WindowManager
                    12/21/2010 11:35:21 PDApp.WindowManager - Destroying PDApp main
                    window's
                    window's sucessfully
                    12/21/2010 11:35:21 PDApp - Terminating ExternalGateway
                    12/21/2010 11:35:21 PDApp.ExternalGateway - ExternalGateway
                    destructed
                    12/21/2010 11:35:21 PDApp - Terminating MessageHandler
                    12/21/2010 11:35:21 PDApp.ExternalGateway - MessageHandler
                    finalize...
                    12/21/2010 11:35:21 PDApp.ExternalGateway - MessageHandler destructed
                    12/21/2010 11:35:21 PDApp - Terminating NativeCommandHandler
                    12/21/2010 11:35:21 PDApp.ExternalGateway - NativeCommandHandler
                    destructed
                    12/21/2010 11:35:21 PDApp - Terminating AsyncMessageProcessor
                    12/21/2010 11:35:21 PDApp.AsyncMsgProcessor - Destroying
                    AsyncMsgProcessor
                    12/21/2010 11:35:21 PDApp - Terminating NativePlatformHandler
                    12/21/2010 11:35:21 PDApp - Terminating logger
                    PDA changed file
                    to 4
                    ErrorCode(212)
                    • 7. Re: "error loading updater workflow"...trying to install camera raw 6.3 plug in
                      This problem normally occurs in case of corrupt runtimes. Please download and install the AAM patch from the link : http://www.adobe.com/support/downloads/detail.jsp?ftpID=4773
                      Once this patch is applied, try applying the camera raw patch again.
                      If this also doesn't solve the problem, then probably reinstalling the product may help.
                      Sourabh
