9 Replies Latest reply on Dec 20, 2010 11:16 AM by kglad
    dreaded error #1068 MyClass and MyClass cannot be reconciled
    birnerseff
      or: why doesn't a switch case without a break work always?
      I have got this code snippet as part of a function defined in MyClass
      var ni:int, np:int, xv:Number, yv:Number;
      for(ni = np = 0 ; ni < cdata.cmds.length ; ni++)
      {       switch(cdata.cmds[ni])
              {       case GraphicsPathCommand.MOVE_TO:
                 /* A: code here to setup a new path*/
                              var b:MyPath = new MyPath();
                         /* B: duplicate switch case
                              xv = cdata.path[np++];
                              yv = cdata.path[np++];
                              b.add(xv, yv);
                              break;
                        // fall through
                       case GraphicsPathCommand.LINE_TO:
                               b.add(xv, yv);
                               break;
                       case GraphicsPathCommand.CURVE_TO:
                               b.add(xv, yv, true);
                               b.add(xv, yv);
                               break;
      the code worked well until I changed the the definition of MyPath and consequently had to change code in the A section.
      This produced the - not very enlightening - error message (which suggests to send the error to Adobe but does not give a link)
      The script would work again after I enabled the B section
        • 1. Re: dreaded error #1068 MyClass and MyClass cannot be reconciled
          copy and paste your complete error message.
          • 2. Re: dreaded error #1068 MyClass and MyClass cannot be reconciled
            birnerseff Level 2
            it is a bit lengthy, though
            verify PlotText/bezigon()
                                    stack:
                                    scope: [global Object$ flash.events::EventDispatcher$ flash.display::DisplayObject$ flash.display::InteractiveObject$ flash.display::DisplayObjectContainer$ flash.display::Sprite$ Material$ PlotObjekt$ PlotText$]
                                     locals: PlotText * * * * * * * * * * * * * *
              0:debugfile "/home/wolfgang/Plotservice;;PlotText.as"
                                    stack:
              2:debugline 273
                                    stack:
              5:getlocal0
                                    stack: PlotText
              6:pushscope
                                    stack:
                                    scope: [global Object$ flash.events::EventDispatcher$ flash.display::DisplayObject$ flash.display::InteractiveObject$ flash.display::DisplayObjectContainer$ flash.display::Sprite$ Material$ PlotObjekt$ PlotText$] PlotText
              7:pushnull
                                    stack: null
              8:coerce Letter
                                    stack: Letter?
              10:setlocal 4
                                    stack:
                                     locals: PlotText * * * Letter? * * * * * * * * * *
              12:pushnull
                                    stack: null
              13:coerce PlotTextFormat
                                    stack: PlotTextFormat?
              15:setlocal 5
                                    stack:
                                     locals: PlotText * * * Letter? PlotTextFormat? * * * * * * * * *
              17:pushnull
                                    stack: null
              18:coerce FontOutlines
                                    stack: FontOutlines?
              21:setlocal 6
                                    stack:
                                     locals: PlotText * * * Letter? PlotTextFormat? FontOutlines? * * * * * * * *
              23:pushnull
                                    stack: null
              24:coerce flash.geom::Matrix
                                    stack: flash.geom::Matrix?
              26:setlocal 7
                                    stack:
                                     locals: PlotText * * * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? * * * * * * *
              28:pushnan
                                    stack: Number
              29:setlocal 8
                                    stack:
                                     locals: PlotText * * * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number * * * * * *
              31:pushnull
                                    stack: null
              32:coerce Object
                                    stack: Object?
              34:setlocal 9
                                    stack:
                                     locals: PlotText * * * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? * * * * *
              36:pushbyte 0
                                    stack: int
              38:setlocal 10
                                    stack:
                                     locals: PlotText * * * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int * * * *
              40:pushbyte 0
                                    stack: int
              42:setlocal 11
                                    stack:
                                     locals: PlotText * * * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int * * *
              44:pushnan
                                    stack: Number
              45:setlocal 12
                                    stack:
                                     locals: PlotText * * * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int Number * *
              47:pushnan
                                    stack: Number
              48:setlocal 13
                                    stack:
                                     locals: PlotText * * * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int Number Number *
              50:debug
                                    stack:
              56:debug
                                    stack:
              62:debug
                                    stack:
              68:debugline 275
                                    stack:
              71:newarray 0
                                    stack: Array
              73:coerce Array
                                    stack: Array
              76:setlocal1
                                    stack:
                                     locals: PlotText Array * * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int Number Number *
              77:debugline 276
                                    stack:
              80:findpropstrict Bezigon
                                    stack: global
              83:constructprop 150 0
                                    stack: Bezigon
              87:coerce Bezigon
                                    stack: Bezigon
              90:setlocal2
                                    stack:
                                     locals: PlotText Array Bezigon * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int Number Number *
              91:debugline 277
                                    stack:
              94:getlocal1
                                    stack: Array
              95:getlocal2
                                    stack: Array Bezigon
              96:callproperty http://adobe.com/AS3/2006/builtin::push 1
                                    stack: uint
              100:pop
                                    stack:
              101:debugline 278
                                    stack:
              104:pushbyte 0
                                    stack: int
              106:convert_i
                                    stack: int
              107:setlocal3
                                    stack:
                                     locals: PlotText Array Bezigon int Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int Number Number *
              108:jump 860
            B0:
                                    stack:
                                     locals: PlotText? Array? Bezigon? int Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int Number Number *
              112:label
                                    stack:
              113:debug
                                    stack:
              120:debug
                                    stack:
              127:debug
                                    stack:
              133:debug
                                    stack:
              139:debug
                                    stack:
              146:debug
                                    stack:
              153:debug
                                    stack:
              160:debug
                                    stack:
              167:debug
                                    stack:
              174:debug
                                    stack:
              181:debugline 279
                                    stack:
              184:getlocal0
                                    stack: PlotText?
              185:getproperty PlotText::letters
                                    stack: Array?
              187:getlocal3
                                    stack: Array? int
              188:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::[]
                                    stack: *
              190:coerce Letter
                                    stack: Letter?
              192:setlocal 4
                                    stack:
              194:debugline 280
                                    stack:
              197:getlocal 4
                                    stack: Letter?
              199:callproperty getPlotTextFormat 0
              203:coerce PlotTextFormat
              205:setlocal 5
                                    stack:
              207:debugline 281
                                    stack:
              210:findpropstrict FontManager
                                    stack: global
              213:getproperty FontManager
                                    stack: FontManager$?
              216:getlocal 5
                                    stack: FontManager$? PlotTextFormat?
              218:getproperty font
                                    stack: FontManager$? String?
              220:getlocal 5
                                    stack: FontManager$? String? PlotTextFormat?
              222:getproperty bold
                                    stack: FontManager$? String? Object?
              224:getlocal 5
                                    stack: FontManager$? String? Object? PlotTextFormat?
              226:getproperty italic
                                    stack: FontManager$? String? Object? Object?
              228:callproperty getOutlineFont 3
              232:coerce FontOutlines
              235:setlocal 6
                                    stack:
              237:debugline 283
                                    stack:
              240:getlocal 4
                                    stack: Letter?
              242:getproperty transform
                                    stack: flash.geom::Transform?
              244:getproperty matrix
              246:coerce flash.geom::Matrix
              248:setlocal 7
                                    stack:
              250:debugline 284
                                    stack:
              253:findpropstrict Number
                                    stack: global
              255:getlocal 5
                                    stack: global PlotTextFormat?
              257:getproperty size
                                    stack: global Object?
              259:callproperty Number 1
                                    stack: *
              262:pushshort 1024
                                    stack: * int
              265:divide
                                    stack: Number
              266:convert_d
                                    stack: Number
              267:setlocal 8
                                    stack:
              269:debugline 285
                                    stack:
              272:getlocal 7
              274:getlocal 7
                                    stack: flash.geom::Matrix? flash.geom::Matrix?
              276:getproperty a
                                    stack: flash.geom::Matrix? Number
              279:getlocal 8
                                    stack: flash.geom::Matrix? Number Number
              281:multiply
              282:setproperty a
                                    stack:
              285:getlocal 7
              287:getlocal 7
              289:getproperty b
              292:getlocal 8
              294:multiply
              295:setproperty b
                                    stack:
              298:getlocal 7
              300:getlocal 7
              302:getproperty c
              305:getlocal 8
              307:multiply
              308:setproperty c
                                    stack:
              311:getlocal 7
              313:getlocal 7
              315:getproperty d
              318:getlocal 8
              320:multiply
              321:setproperty d
                                    stack:
              324:debugline 286
                                    stack:
              327:getlocal 7
              329:getlocal 7
              331:getproperty ty
              334:getlocal 4
                                    stack: flash.geom::Matrix? Number Letter?
              336:getproperty ht
              339:add
              340:setproperty ty
                                    stack:
              343:debugline 287
                                    stack:
              346:findpropstrict trace
                                    stack: global
              348:pushstring "text "
                                    stack: global String
              351:getlocal 4
                                    stack: global String Letter?
              353:getproperty text
                                    stack: global String String?
              355:add
              356:pushstring " mtx "
              359:add
              360:getlocal 7
                                    stack: global String flash.geom::Matrix?
              362:add
              363:callproperty trace 1
                                    stack: void?
              366:pop
                                    stack:
              367:debugline 288
                                    stack:
              370:getlocal 6
              372:getlocal 4
                                    stack: FontOutlines? Letter?
              374:getproperty text
                                    stack: FontOutlines? String?
              376:pushbyte 0
                                    stack: FontOutlines? String? int
              378:callproperty http://adobe.com/AS3/2006/builtin::charCodeAt 1
                                    stack: FontOutlines? Number
              382:getlocal 7
                                    stack: FontOutlines? Number flash.geom::Matrix?
              384:callproperty getOutlineData 2
                                    stack: Object?
              388:coerce Object
                                    stack: Object?
              390:setlocal 9
                                    stack:
              392:debugline 291
                                    stack:
              395:pushbyte 0
                                    stack: int
              397:dup
                                    stack: int int
              398:setlocal 14
                                    stack: int
                                     locals: PlotText? Array? Bezigon? int Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int Number Number int
              400:convert_i
                                    stack: int
              401:setlocal 11
                                    stack:
              403:getlocal 14
                                    stack: int
              405:kill 14
                                    stack: int
              407:convert_i
                                    stack: int
              408:setlocal 10
                                    stack:
              410:jump 788
            B1:
                                    stack:
              414:label
                                    stack:
              415:jump 661
            B2:
                                    stack:
              419:label
                                    stack:
              420:debugline 294
                                    stack:
              423:getlocal2
                                    stack: Bezigon?
              424:getproperty length
                                    stack: uint
              426:convert_b
                                    stack: Boolean
              427:iffalse 480
                                    stack:
              431:debugline 295
                                    stack:
              434:getlocal2
                                    stack: Bezigon?
              435:getlocal2
                                    stack: Bezigon? Bezigon?
              436:getproperty length
                                    stack: Bezigon? uint
              438:pushbyte 1
                                    stack: Bezigon? uint int
              440:subtract
                                    stack: Bezigon? Number
              441:getlocal2
                                    stack: Bezigon? Number Bezigon?
              442:pushbyte 0
                                    stack: Bezigon? Number Bezigon? int
              444:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::[]
                                    stack: Bezigon? Number *
              446:setproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::[]
                                    stack:
              448:debugline 296
                                    stack:
              451:getlocal2
                                    stack: Bezigon?
              452:pushtrue
                                    stack: Bezigon? Boolean
              453:setproperty closed
                                    stack:
              456:debugline 297
                                    stack:
              459:findpropstrict Bezigon
                                    stack: global
              462:constructprop 150 0
                                    stack: Bezigon
              466:coerce Bezigon
                                    stack: Bezigon
              469:setlocal2
                                    stack:
                                     locals: PlotText? Array? Bezigon int Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int Number Number *
              470:debugline 298
                                    stack:
              473:getlocal1
                                    stack: Array?
              474:getlocal2
                                    stack: Array? Bezigon
              475:callproperty http://adobe.com/AS3/2006/builtin::push 1
                                    stack: uint
              479:pop
            B3:
                                    stack:
                                    scope: [global Object$ flash.events::EventDispatcher$ flash.display::DisplayObject$ flash.display::InteractiveObject$ flash.display::DisplayObjectContainer$ flash.display::Sprite$ Material$ PlotObjekt$ PlotText$] PlotText?
              480:label
                                    stack:
              481:debugline 306
                                    stack:
              484:getlocal 9
                                    stack: Object?
              486:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::path
                                    stack: *
              489:getlocal 11
                                    stack: * int
              491:dup
                                    stack: * int int
              492:increment_i
                                    stack: * int int
              493:convert_i
                                    stack: * int int
              494:setlocal 11
                                    stack: * int
              496:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::[]
                                    stack: *
              498:convert_d
                                    stack: Number
              499:setlocal 12
                                    stack:
              501:debugline 307
                                    stack:
              504:getlocal 9
                                    stack: Object?
              506:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::path
                                    stack: *
              509:getlocal 11
                                    stack: * int
              511:dup
                                    stack: * int int
              512:increment_i
                                    stack: * int int
              513:convert_i
                                    stack: * int int
              514:setlocal 11
                                    stack: * int
              516:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::[]
                                    stack: *
              518:convert_d
                                    stack: Number
              519:setlocal 13
                                    stack:
              521:debugline 308
                                    stack:
              524:getlocal2
                                    stack: Bezigon?
              525:getlocal 12
              527:getlocal 13
                                    stack: Bezigon? Number Number
              529:callproperty add 2
                                    stack: void?
              533:pop
                                    stack:
              534:debugline 309
                                    stack:
              537:jump 779
            B4:
                                    stack:
              541:label
                                    stack:
              542:debugline 311
                                    stack:
              545:getlocal 9
                                    stack: Object?
              547:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::path
                                    stack: *
              550:getlocal 11
                                    stack: * int
              552:dup
                                    stack: * int int
              553:increment_i
                                    stack: * int int
              554:convert_i
                                    stack: * int int
              555:setlocal 11
                                    stack: * int
              557:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::[]
                                    stack: *
              559:convert_d
                                    stack: Number
              560:setlocal 12
                                    stack:
              562:debugline 312
                                    stack:
              565:getlocal 9
                                    stack: Object?
              567:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::path
                                    stack: *
              570:getlocal 11
                                    stack: * int
              572:dup
                                    stack: * int int
              573:increment_i
                                    stack: * int int
              574:convert_i
                                    stack: * int int
              575:setlocal 11
                                    stack: * int
              577:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::[]
                                    stack: *
              579:convert_d
                                    stack: Number
              580:setlocal 13
                                    stack:
              582:debugline 313
                                    stack:
              585:getlocal2
                                    stack: Bezigon?
              586:getlocal 12
              588:getlocal 13
              590:pushtrue
                                    stack: Bezigon? Number Number Boolean
              591:callproperty add 3
                                    stack: void?
              595:pop
                                    stack:
              596:debugline 314
                                    stack:
              599:getlocal 9
                                    stack: Object?
              601:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::path
                                    stack: *
              604:getlocal 11
                                    stack: * int
              606:dup
                                    stack: * int int
              607:increment_i
                                    stack: * int int
              608:convert_i
                                    stack: * int int
              609:setlocal 11
                                    stack: * int
              611:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::[]
                                    stack: *
              613:convert_d
                                    stack: Number
              614:setlocal 12
                                    stack:
              616:debugline 315
                                    stack:
              619:getlocal 9
                                    stack: Object?
              621:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::path
                                    stack: *
              624:getlocal 11
                                    stack: * int
              626:dup
                                    stack: * int int
              627:increment_i
                                    stack: * int int
              628:convert_i
                                    stack: * int int
              629:setlocal 11
                                    stack: * int
              631:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::[]
                                    stack: *
              633:convert_d
                                    stack: Number
              634:setlocal 13
                                    stack:
              636:debugline 316
                                    stack:
              639:getlocal2
                                    stack: Bezigon?
              640:getlocal 12
              642:getlocal 13
              644:callproperty add 2
                                    stack: void?
              648:pop
                                    stack:
              649:debugline 317
                                    stack:
              652:jump 779
            B5:
                                    stack:
              656:label
                                    stack:
              657:jump 779
            B6:
                                    stack:
              661:debugline 292
                                    stack:
              664:getlocal 9
                                    stack: Object?
              666:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::cmds
                                    stack: *
              669:getlocal 10
                                    stack: * int
              671:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::[]
                                    stack: *
              673:setlocal 14
                                    stack:
              675:debugline 293
                                    stack:
              678:findpropstrict flash.display::GraphicsPathCommand
                                    stack: global
              681:getproperty flash.display::GraphicsPathCommand
                                    stack: flash.display::GraphicsPathCommand$?
              684:getproperty MOVE_TO
                                    stack: int
              687:getlocal 14
                                    stack: int *
              689:ifstrictne 699
                                    stack:
              693:pushshort 0
                                    stack: int
              695:jump 760
            B7:
                                    stack:
              699:debugline 305
                                    stack:
              702:findpropstrict flash.display::GraphicsPathCommand
                                    stack: global
              705:getproperty flash.display::GraphicsPathCommand
              708:getproperty LINE_TO
                                    stack: int
              711:getlocal 14
                                    stack: int *
              713:ifstrictne 723
                                    stack:
              717:pushshort 1
                                    stack: int
              719:jump 760
            B8:
                                    stack:
              723:debugline 310
                                    stack:
              726:findpropstrict flash.display::GraphicsPathCommand
                                    stack: global
              729:getproperty flash.display::GraphicsPathCommand
              732:getproperty CURVE_TO
                                    stack: int
              735:getlocal 14
                                    stack: int *
              737:ifstrictne 747
                                    stack:
              741:pushshort 2
                                    stack: int
              743:jump 760
            B9:
                                    stack:
              747:pushfalse
                                    stack: Boolean
              748:iffalse 758
                                    stack:
              752:pushshort 3
                                    stack: int
              754:jump 760
            B10:
                                    stack:
              758:pushshort 3
            B11:
                                    stack: int
              760:kill 14
                                    stack: int
              762:lookupswitch default:656 maxcase:3 419 480 541 656
            B12:
                                    stack:
              779:debugline 291
                                    stack:
              782:getlocal 10
                                    stack: int
              784:increment_i
                                    stack: int
              785:convert_i
                                    stack: int
              786:setlocal 10
            B13:
                                    stack:
              788:getlocal 10
                                    stack: int
              790:getlocal 9
                                    stack: int Object?
              792:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::cmds
                                    stack: int *
              795:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.d isplay:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.d isplay:DisplayObject,flash.events:EventDispatcher,Object}::length
                                    stack: int *
              798:iflt 414
            VerifyError: Error #1068: PlotText und PlotText können nicht angeglichen werden.
                at PlotText/bezigon()
                at Arbeitsbereich/bezmsgbox_choose()[/home/wolfgang/Plotservice/Arbeitsbereich.as:2142]
                at flash.events::EventDispatcher/dispatchEventFunction()
                at flash.events::EventDispatcher/dispatchEvent()
                at Msgbox/okbtn()[/home/wolfgang/Plotservice/Msgbox.as:68]
            273            override public function bezigon():Array
            274            {
            275                var ret:Array = [];
            276                var b:Bezigon = new Bezigon();
            277                ret.push(b);
            278                for(var n:int = 0 ; n < letters.length ; n++)
            279                {    var l:Letter = letters[n];
            280                    var fmt:PlotTextFormat = l.getPlotTextFormat();
            281                    var font:FontOutlines = FontManager.getOutlineFont(fmt.font, fmt.bold, fmt.italic);
            282                // sonst noch relevant? (schon in mtx enthalten): condense, slant, yoffs
            283                    var mtx:Matrix = l.transform.matrix;
            284                    var sc:Number = Number(fmt.size) / 1024;
            285                    mtx.a *= sc; mtx.b *= sc; mtx.c *= sc; mtx.d *= sc;
            286                    mtx.ty += l.ht;
            287    trace('text '+l.text+' mtx '+mtx);
            288                    var cdata:Object = font.getOutlineData(l.text.charCodeAt(0), mtx);
            289    //trace('path '+cdata.path);
            290                    var ni:int, np:int, xv:Number, yv:Number;
            291                    for(ni = np = 0 ; ni < cdata.cmds.length ; ni++)
            292                    {    switch(cdata.cmds[ni])
            293                        {    case GraphicsPathCommand.MOVE_TO:
            294                                if(b.length)
            295                                {    b[b.length-1] = b[0];
            296                                    b.closed = true;
            297                                    b = new Bezigon();
            298                                    ret.push(b);
            299                                }
            300                            //    xv = cdata.path[np++];
            301                            //    yv = cdata.path[np++];
            302                            //    b.add(xv, yv);
            303                            //    break;
            304                            // fall through
            305                            case GraphicsPathCommand.LINE_TO:
            306                                xv = cdata.path[np++];
            307                                yv = cdata.path[np++];
            308                                b.add(xv, yv);
            309                                break;
            310                            case GraphicsPathCommand.CURVE_TO:
            311                                xv = cdata.path[np++];
            312                                yv = cdata.path[np++];
            313                                b.add(xv, yv, true);
            314                                xv = cdata.path[np++];
            315                                yv = cdata.path[np++];
            316                                b.add(xv, yv);
            317                                break;
            318                        }
            319                    }
            320                    if(b.length > 0)
            321                    {    b[b.length-1] = b[0];
            322                        b.closed = true;
            323                    }
            324    trace('bezigon '+b);
            325                }
            326                return ret;
            327            }
            • 3. Re: dreaded error #1068 MyClass and MyClass cannot be reconciled
              that's all error message?  there's no trace() output there?
              • 4. Re: dreaded error #1068 MyClass and MyClass cannot be reconciled
                birnerseff Level 2
                nothing useful... it reported just the line number where the function was called from.
                The very last line of that code analysis looks like the verifier had detected an invalid byte code address
                • 5. Re: dreaded error #1068 MyClass and MyClass cannot be reconciled
                  what are the first few lines of the error output without any trace output?
                  • 6. Re: dreaded error #1068 MyClass and MyClass cannot be reconciled
                    birnerseff Level 2
                    well, exactly that...
                    There was a trace of mine "about to call that func", followed by flash's "verify function()" with all that detail, the #1068 message, and finally the call stack
                    • 7. Re: dreaded error #1068 MyClass and MyClass cannot be reconciled
                                              stack:
                      is part of your error message?  are you using a debugger (or the flash debugger)?
                      • 8. Re: dreaded error #1068 MyClass and MyClass cannot be reconciled
                        birnerseff Level 2
                        this is running a debug-enabled swf in debug version of standalone player. The long text appears in the flashlog.txt file; the short version just has the "cannot be reconciled" message followed by the call stack
                        • 9. Re: dreaded error #1068 MyClass and MyClass cannot be reconciled
                          in the flash ide, click control/test movie/and possibly another test.   copy and paste the first 20 lines of the error message.
