6 Replies Latest reply on Dec 20, 2010 5:10 AM by userben
    I can't seem to import as classes from other files
    userben Level 1
      This is driving me crazy, I've been trying to resolve this on my own for ages, and I've reviewed a lot of different materials, but I still can't seem to just import some external actionscript classes correctly.
      I'm using Flash Builder 4 with the Flex 4 SDK on mac osx 10.6
      the class I'm trying to import (I'll call it DesiredClass) is in a folder like this
      /libraries/com/foreignproject/com/foreignproject/DesiredClass.as
      within the class itself, the package declaration looks like this (I left all the guts out for clarity):
      package com.foreignproject
          import flash.display.Sprite;
          public class DesiredClass extends Sprite
              public function DesiredClass()
      I'm working on a totally different actionscript file at
      /Users/username/Documents/Adobe Flash Builder 4/TestProject/src/TestProject.as
      in this file I try to import the DesiredClass:
      package
           import com.foreignproject.DesiredClass;
           public class TestProject extends Sprite
                public function TestProject()
                var neatClass:DesiredClass = new DesiredClass();
      And then I try to add the class I want to the source path.
      I've tried adding each folder to the source path separately:
      If I choose the libraries folder or either of the com folders then an error shows up in the TestProject.as file, saying:
      Definition com.foreignproject:DesiredClass could not be found.
      But f I choose either of the foreignproject folders then an error shows up in the DesiredClass.as file saying:
      a file found in a source-path must have the same package structure 'com.foreignproject', as the definition's package, ".
      What am I doing wrong? Please help. I bought a book on actionscript, started doing the flex-in-a-week series, read numerous online discussion boards, and I still can't import these classes.
      Thanks in advance.
        • 1. Re: I can't seem to import as classes from other files
          Lee Burrows Level 4
          try adding a source folder path rather than linking to the .as file itself.
          folder path of libraries/com/foreignproject is what you need i think
          • 2. Re: I can't seem to import as classes from other files
            userben Level 1
            Hi Lee,
            Thanks for responding!
            I don't quite understand your answer.
            Are you suggesting that I insert a different import statement?:
            import libraries.com.foreignproject
            or are you suggesting that I add the foreignproject folder to the source path?
            I have already tried adding the foreignproject folder to the source path, but this results in the same "not found" error.
            • 3. Re: I can't seem to import as classes from other files
              Lee Burrows Level 4
              yep, i meant add folder to source path.
              • 4. Re: I can't seem to import as classes from other files
                userben Level 1
                Yeah I still get a "does not exist" error.
                Below are the steps I use to add it to the source path:
                right click on Main Project Package in Package Explorer
                    select "Properties"
                        select "ActionScript Build Path"
                            click "Source path"
                                click "Add Folder"
                                    click "Browse…"
                                        browse for folder: "libraries/com/foreignproject"
                                        it gets translated automatically to:
                                            "$[com]/foreignproject"
                                        click "Choose"
                                    click "OK"
                                click "OK"
                That is how I add a folder to the source path.
                Please let me know if I'm not doing that right.
                • 5. Re: I can't seem to import as classes from other files
                  Lee Burrows Level 4
                  maybe FB is getting confused by the folder structure (/libraries/com/foreignproject/com/foreignproject/) as you have repeated the com/foreignproject path (when it internally replaces $[com] with the full path?
                  can you overwrite "$[com]/foreignproject" and replace it with a full path (eg c:/folder/path/etc/libraries/com/foreignproject/com/foreignproject/ ?
                  • 6. Re: I can't seem to import as classes from other files
                    userben Level 1
                    Thanks Lee for your continued help.
                    I tried to manually edit the folder path, but Flash Buider said that it was an invalid path and insisted on inserting "$[com]/foreignproject"
                    So I just moved the folder to eliminate the repeated names, and now the path is:
                    /Users/username/Documents/code/libraries/as/com/foreignproject/DesiredClass.as
                    but I still run into the same problems, either it says that "DesiredClass cannot be found" (when I select the com folder)
                    or it says that there is an error with the package name in DesiredClass (when I select the foreignproject folder)
