Is there a way to change the order of subkeywords in the
index? We are using See and See also references, and want them to
be displayed first under the main keyword.
There certainly is. First, you need to ensure you aren't
using a Binary Index. So click File > Project Settings... >
General tab and DE-select the Binary Index option.
Once you do this, you should be able to order the sub
keywords as you want.
Ha! Maybe door #3: Prefix the other subs with "the" to force
them after See!
What's interesting is that in the source code for the HHK
file, the entries appear in whatever order I dragged them.
Something is re-rendering them alphabetically for display in the
index. But what? But what?
Well, I think it's the fact your layout type is WebHelp. This
is why the keywords don't automatically allow you to move them. I
think it's probably because in the world of compiled .CHM, the .HHK
file is used. But during the WebHelp generation process, the .HHK
is converted to what WebHelp needs. And this means that an
arbitrary listing will fail.
Note that this trick has a slight flaw in that "." is not the
first punctuation character in the ordering used by RH, so certain
words will still come ahead of "...see also". In my case, this
shows up when I document command line flags like "-i". You may not
have any index items with this problem.
