2 Replies Latest reply on Dec 19, 2010 4:16 PM by pwillener
    Updating Acrobat Reader ver 7
    species8350 Level 1
      I have Acrobat ver 7 on my pc (Vista 32 bit). I keep getting messages regarding updating.
      I see a number of Acrobat versions, eg X, 9.4, and 8.2, but they all seem so big.
      I just want a good reader that does the job.
      Can anyone offer any advice?
      A
      Ps. I use IE ver 8
      PPs. what does 'X' mean regarding the reader?
        • 1. Re: Updating Acrobat Reader ver 7
          Claudio González Most Valuable Participant
          I have read of several applications, many of them free, that can read PDF files, but I have also read that at least some of the most popular ones install additional software that's nearly impossible to remove (and I understand that so does Reader as well if you are nor careful when installing). As I use Acrobat and therefore do not need a separate application for reading PDFs, I have no direct experience on this.
          The newer versions of Reader are by no means gigantic applications unless you have severe hard disk space limitations, in which case I would stronlgy advise you to get a larger HD or clear as much as you can your existing one.
          As far as I know, the "X" stands for 10.
          Hope this helps.
          • 2. Re: Updating Acrobat Reader ver 7
            pwillener Level 8
            Reader 7 is old and no longer supported, and therefore vulnerable.
            I use Reader 8.2 on my old Windows 2000 machine; it is supported for the time being, and not that awfully large.
