1 Reply Latest reply on Dec 19, 2010 9:18 AM by saisri2k2
    ComboBox values color change based on "if" condition
    Rajeshb_Flash Level 1
      I need a small help from you guys. I am doing a simple combobox example. Now my requirement was, i want to differentiate the combobox values with some colors based on a condition.
      Suppose for ex: if my combobox data value exceeds 200 i want to display the items in "red" else i want to display in "green". i need solutions for this requirment.
      your help would be appreciated. i need it asap. kindly refer the attached image, that is what i am looking for. my output should look like that.
      <!-- Simple example to demonstrate the Halo ComboBox control. -->
                     xmlns:mx="library://ns.adobe.com/flex/mx">
          <fx:Script>
              <![CDATA[
                  import mx.collections.ArrayCollection;
                  import mx.events.DropdownEvent;
                  [Bindable]
                  public var cards:ArrayCollection = new ArrayCollection(
                      [ {label:"Value1", data:100},
                          {label:"Value2", data:200},
                          {label:"Value3", data:300},
                          {label:"Value4", data:400},
                          {label:"Value5", data:500}]);
                  private function closeHandler(evt:DropdownEvent):void {
                      myLabel.text = "You selected: " +  ComboBox(evt.target).selectedItem.label;
                      myData.text = "Data: " +  ComboBox(evt.target).selectedItem.data;
          </fx:Script>
          <s:Panel title="Halo ComboBox Control Example"
                   width="75%" height="75%"
                   horizontalCenter="0" verticalCenter="0">
              <s:HGroup left="10" right="10" top="10" bottom="10">
                  <mx:ComboBox dataProvider="{cards}" width="150"
                               close="closeHandler(event);"/>
                  <s:VGroup width="250">
                      <s:Label width="200" color="blue" text="Select a type of credit card."/>
                      <s:Label id="myLabel" text="You selected:"/>
                      <s:Label id="myData" text="Data:"/>
                  </s:VGroup>
              </s:HGroup>
          </s:Panel>
      </s:Application>
      Rajesh
        • 1. Re: ComboBox values color change based on "if" condition
          saisri2k2 Level 4
          <mx:ComboBox id="cbCombo" dataProvider="{myData}" labelField="price" >
                    <mx:itemRenderer>
                         <fx:Component>
                              <mx:Text color="{data.price>2?0xff0000:0x00ff00}" text="{data.name}"/>
                         </fx:Component>
                    </mx:itemRenderer>
               </mx:ComboBox>
          put this in the place of your combobox
          If this answer helped you, Please mark it as such.
