0 Replies Latest reply on Dec 20, 2010 12:13 AM by eyall
    trying to launch Flash builder 4 results in a crash.
    eyall
      After installing the Flash builder 4 any attemp to launch it results in a crash with the following message :
      A fatal error has been detected by the Java Runtime Environment:
        Internal Error (0xe06d7363), pid=2612, tid=2548
      JRE version: 6.0_16-b01
      Java VM: Java HotSpot(TM) Client VM (14.2-b01 mixed mode windows-x86 )
      Problematic frame:
      C  [kernel32.dll+0x12afb]
      An error report file with more information is saved as:
      C:\Documents and Settings\eyal.EYAL-NEW2\hs_err_pid2612.log
      If you would like to submit a bug report, please visit:
         http://java.sun.com/webapps/bugreport/crash.jsp
      The crash happened outside the Java Virtual Machine in native code.
      See problematic frame for where to report the bug.
      the error log output :
      # A fatal error has been detected by the Java Runtime Environment:
      #  Internal Error (0xe06d7363), pid=2856, tid=3052
      # JRE version: 6.0_16-b01
      # Java VM: Java HotSpot(TM) Client VM (14.2-b01 mixed mode windows-x86 )
      # Problematic frame:
      # C  [kernel32.dll+0x12afb]
      # If you would like to submit a bug report, please visit:
      #   http://java.sun.com/webapps/bugreport/crash.jsp
      # The crash happened outside the Java Virtual Machine in native code.
      # See problematic frame for where to report the bug.
      ---------------  T H R E A D  ---------------
      Current thread (0x00906c00):  JavaThread "main" [_thread_in_native, id=3052, stack(0x00030000,0x00130000)]
      siginfo: ExceptionCode=0xe06d7363, ExceptionInformation=0x19930520 0x0012be20 0x35f00800
      Registers:
      EAX=0x0012bd78, EBX=0x0012bee0, ECX=0x00000000, EDX=0x00000003
      ESP=0x0012bd74, EBP=0x0012bdc8, ESI=0x0012be00, EDI=0x0012c194
      EIP=0x7c812afb, EFLAGS=0x00000206
      Top of Stack: (sp=0x0012bd74)
      0x0012bd74:   0012bec4 e06d7363 00000001 00000000
      0x0012bd84:   7c812afb 00000003 19930520 0012be20
      0x0012bd94:   35f00800 360bb9a8 360bda10 00000017
      0x0012bda4:   00000017 0012be2c 00000000 35e119cf
      0x0012bdb4:   360bb9a8 0000001f 360bda10 00000017
      0x0012bdc4:   0012c194 0012be00 35e5716a e06d7363
      0x0012bdd4:   00000001 00000003 0012bdf4 e06d7363
      0x0012bde4:   00000001 00000000 00000000 00000003
      Instructions: (pc=0x7c812afb)
      0x7c812aeb:   8d 7d c4 f3 a5 5f 8d 45 b0 50 ff 15 10 15 80 7c
      0x7c812afb:   5e c9 c2 10 00 85 ff 0f 8e 36 93 ff ff 8b 55 fc
      Stack: [0x00030000,0x00130000],  sp=0x0012bd74,  free space=1007k
      Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
      C  [amtservices.dll+0x4716a]
      C  [amtservices.dll+0x727a8]
      Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
      j  com.adobe.flexide.amt.AMTLib.AMTObtainProductLicense(IILjava/lang/String;Ljava/lang/Strin g;Ljava/lang/String;Ljava/lang/String;IILjava/lang/String;)I+0
      j  com.adobe.flexide.amt.AMTLib.ObtainProductLicense(Ljava/lang/String;Ljava/lang/String;Lja va/lang/String;Ljava/lang/String;IILjava/lang/String;Z)I+27
      j  com.adobe.flexide.amt.Activator.AMT_ObtainLicense(Ljava/lang/String;Ljava/lang/String;IIZ )I+32
      j  com.adobe.flexbuilder.ui.asn.ASNUIBridge.start()Z+43
      j  com.adobe.flexbuilder.ui.UIPlugin.start(Lorg/osgi/framework/BundleContext;)V+21
      j  org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run()Ljava/lang/Object;+64
      v  ~StubRoutines::call_stub
      j  java.security.AccessController.doPrivileged(Ljava/security/PrivilegedExceptionAction;)Lja va/lang/Object;+0
      j  org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(Lorg/osgi/frame work/BundleActivator;)V+22
      j  org.eclipse.osgi.framework.internal.core.BundleContextImpl.start()V+23
      j  org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(I)V+379
      j  org.eclipse.osgi.framework.internal.core.AbstractBundle.start(I)V+20
      j  org.eclipse.osgi.framework.util.SecureAction.start(Lorg/osgi/framework/Bundle;I)V+8
      J  org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(Ljava/lan g/String;Ljava/lang/Class;Lorg/eclipse/osgi/baseadaptor/loader/ClasspathManager;)V
      J  org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(Ljava/lang/String;)Lj ava/lang/Class;
      J  org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(Ljava/lang/String;)Ljava/lan g/Class;
      j  org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(Ljava/lang/String;)Ljava/l ang/Class;+8
      J  org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(Ljava/lang/String;ZLjava/ lang/ClassLoader;)Ljava/lang/Class;
      J  org.eclipse.osgi.internal.loader.BundleLoader.findClass(Ljava/lang/String;Z)Ljava/lang/Cl ass;
      J  org.eclipse.osgi.internal.loader.BundleLoader.findClass(Ljava/lang/String;)Ljava/lang/Cla ss;
      J  org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(Ljava/lang/String;Z)Lj ava/lang/Class;
      J  java.lang.ClassLoader.loadClass(Ljava/lang/String;)Ljava/lang/Class;
      J  java.lang.ClassLoader.loadClassInternal(Ljava/lang/String;)Ljava/lang/Class;
      j  com.adobe.flexbuilder.standalone.SplashHandler.init(Lorg/eclipse/swt/widgets/Shell;)V+120
      j  org.eclipse.ui.internal.Workbench$6.run()V+174
      j  org.eclipse.core.runtime.SafeRunner.run(Lorg/eclipse/core/runtime/ISafeRunnable;)V+5
      j  org.eclipse.ui.internal.Workbench.createSplashWrapper()V+32
      j  org.eclipse.ui.internal.Workbench.runUI()I+111
      j  org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/internal/Workbench;)I+1
      j  org.eclipse.ui.internal.Workbench$5.run()V+55
      j  org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databindin g/observable/Realm;Ljava/lang/Runnable;)V+12
      j  org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display; Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
      j  org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/ecl ipse/ui/application/WorkbenchAdvisor;)I+2
      j  com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(Lorg/eclipse/equinox/app/IA pplicationContext;)Ljava/lang/Object;+100
      j  org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Objec t;+135
      j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Ob ject;)Ljava/lang/Object;+103
      j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Lja va/lang/Object;+29
      j  org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object; +149
      j  org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnabl e;)Ljava/lang/Object;+183
      j  sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object; [Ljava/lang/Object;)Ljava/lang/Object;+0
      j  sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/l ang/Object;+87
      j  sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Lja va/lang/Object;+6
      j  java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+ 161
      j  org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+21 1
      j  org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+114
      j  org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
      ---------------  P R O C E S S  ---------------
      Java Threads: ( => current thread )
        0x33ee8400 JavaThread "Thread-1" [_thread_in_native, id=3284, stack(0x35ad0000,0x35bd0000)]
        0x337c8000 JavaThread "Worker-1" [_thread_blocked, id=3304, stack(0x34d00000,0x34e00000)]
        0x33e81800 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=3308, stack(0x34ba0000,0x34ca0000)]
        0x33d5e400 JavaThread "Provisioning Event Dispatcher" daemon [_thread_blocked, id=3292, stack(0x349a0000,0x34aa0000)]
        0x34184c00 JavaThread "Worker-0" [_thread_blocked, id=3360, stack(0x348a0000,0x349a0000)]
        0x33f51c00 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=3508, stack(0x33f80000,0x34080000)]
        0x336ee400 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=3408, stack(0x33a80000,0x33b80000)]
        0x336bc800 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=3456, stack(0x33980000,0x33a80000)]
        0x336d8800 JavaThread "State Saver" [_thread_blocked, id=2624, stack(0x33880000,0x33980000)]
        0x32d87400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3452, stack(0x333f0000,0x334f0000)]
        0x32d81800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=2876, stack(0x332f0000,0x333f0000)]
        0x32d7bc00 JavaThread "Attach Listener" daemon [_thread_blocked, id=2796, stack(0x331f0000,0x332f0000)]
        0x32d7a800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=3320, stack(0x330f0000,0x331f0000)]
        0x32d64c00 JavaThread "Finalizer" daemon [_thread_blocked, id=1432, stack(0x32ff0000,0x330f0000)]
        0x32d63400 JavaThread "Reference Handler" daemon [_thread_blocked, id=3288, stack(0x32ef0000,0x32ff0000)]
      =>0x00906c00 JavaThread "main" [_thread_in_native, id=3052, stack(0x00030000,0x00130000)]
      Other Threads:
        0x32d60400 VMThread [stack: 0x32df0000,0x32ef0000] [id=2892]
        0x32d89c00 WatcherThread [stack: 0x334f0000,0x335f0000] [id=3448]
      VM state:not at safepoint (normal execution)
      VM Mutex/Monitor currently owned by a thread: None
      Heap
      def new generation   total 18176K, used 4329K [0x029e0000, 0x03d90000, 0x05140000)
        eden space 16192K,  20% used [0x029e0000, 0x02d30c68, 0x039b0000)
        from space 1984K,  47% used [0x03ba0000, 0x03c89a88, 0x03d90000)
        to   space 1984K,   0% used [0x039b0000, 0x039b0000, 0x03ba0000)
      tenured generation   total 241984K, used 10583K [0x05140000, 0x13d90000, 0x229e0000)
         the space 241984K,   4% used [0x05140000, 0x05b95c38, 0x05b95e00, 0x13d90000)
      compacting perm gen  total 65536K, used 15300K [0x229e0000, 0x269e0000, 0x329e0000)
         the space 65536K,  23% used [0x229e0000, 0x238d13a8, 0x238d1400, 0x269e0000)
      No shared spaces configured.
      Dynamic libraries:
      0x00400000 - 0x0040e000 C:\Program Files\Adobe\Adobe Flash Builder 4\FlashBuilderC.exe
      0x7c900000 - 0x7c9b2000 C:\WINDOWS\system32\ntdll.dll
      0x7c800000 - 0x7c8f6000 C:\WINDOWS\system32\kernel32.dll
      0x7e410000 - 0x7e4a1000 C:\WINDOWS\system32\USER32.dll
      0x77f10000 - 0x77f59000 C:\WINDOWS\system32\GDI32.dll
      0x5d090000 - 0x5d12a000 C:\WINDOWS\system32\COMCTL32.dll
      0x77dd0000 - 0x77e6b000 C:\WINDOWS\system32\ADVAPI32.dll
      0x77e70000 - 0x77f03000 C:\WINDOWS\system32\RPCRT4.dll
      0x77fe0000 - 0x77ff1000 C:\WINDOWS\system32\Secur32.dll
      0x77c10000 - 0x77c68000 C:\WINDOWS\system32\MSVCRT.dll
      0x76390000 - 0x763ad000 C:\WINDOWS\system32\IMM32.DLL
      0x629c0000 - 0x629c9000 C:\WINDOWS\system32\LPK.DLL
      0x74d90000 - 0x74dfb000 C:\WINDOWS\system32\USP10.dll
      0x72000000 - 0x72014000 C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.0.200.v20090519\eclipse_1206.dll
      0x77c00000 - 0x77c08000 C:\WINDOWS\system32\VERSION.dll
      0x6d800000 - 0x6da8b000 C:\Program Files\Adobe\Adobe Flash Builder 4\jre\bin\client\jvm.dll
      0x76b40000 - 0x76b6d000 C:\WINDOWS\system32\WINMM.dll
      0x7c340000 - 0x7c396000 C:\WINDOWS\system32\MSVCR71.dll
      0x6d7b0000 - 0x6d7bc000 C:\Program Files\Adobe\Adobe Flash Builder 4\jre\bin\verify.dll
      0x6d330000 - 0x6d34f000 C:\Program Files\Adobe\Adobe Flash Builder 4\jre\bin\java.dll
      0x6d290000 - 0x6d298000 C:\Program Files\Adobe\Adobe Flash Builder 4\jre\bin\hpi.dll
      0x76bf0000 - 0x76bfb000 C:\WINDOWS\system32\PSAPI.DLL
      0x6d7f0000 - 0x6d7ff000 C:\Program Files\Adobe\Adobe Flash Builder 4\jre\bin\zip.dll
      0x68000000 - 0x68036000 C:\WINDOWS\system32\rsaenh.dll
      0x769c0000 - 0x76a74000 C:\WINDOWS\system32\USERENV.dll
      0x5b860000 - 0x5b8b5000 C:\WINDOWS\system32\netapi32.dll
      0x6d610000 - 0x6d623000 C:\Program Files\Adobe\Adobe Flash Builder 4\jre\bin\net.dll
      0x71ab0000 - 0x71ac7000 C:\WINDOWS\system32\WS2_32.dll
      0x71aa0000 - 0x71aa8000 C:\WINDOWS\system32\WS2HELP.dll
      0x71a50000 - 0x71a8f000 C:\WINDOWS\System32\mswsock.dll
      0x76f20000 - 0x76f47000 C:\WINDOWS\system32\DNSAPI.dll
      0x76fb0000 - 0x76fb8000 C:\WINDOWS\System32\winrnr.dll
      0x76f60000 - 0x76f8c000 C:\WINDOWS\system32\WLDAP32.dll
      0x76fc0000 - 0x76fc6000 C:\WINDOWS\system32\rasadhlp.dll
      0x6d630000 - 0x6d639000 C:\Program Files\Adobe\Adobe Flash Builder 4\jre\bin\nio.dll
      0x34ca0000 - 0x34cf9000 C:\Program Files\Adobe\Adobe Flash Builder 4\configuration\org.eclipse.osgi\bundles\298\1\.cp\swt-win32-3555.dll
      0x774e0000 - 0x7761e000 C:\WINDOWS\system32\ole32.dll
      0x77120000 - 0x771ab000 C:\WINDOWS\system32\OLEAUT32.dll
      0x763b0000 - 0x763f9000 C:\WINDOWS\system32\comdlg32.dll
      0x773d0000 - 0x774d3000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-w w_61e65202\COMCTL32.dll
      0x77f60000 - 0x77fd6000 C:\WINDOWS\system32\SHLWAPI.dll
      0x7c9c0000 - 0x7d1d7000 C:\WINDOWS\system32\SHELL32.dll
      0x3d930000 - 0x3da16000 C:\WINDOWS\system32\WININET.dll
      0x34e10000 - 0x34e19000 C:\WINDOWS\system32\Normaliz.dll
      0x78130000 - 0x78263000 C:\WINDOWS\system32\urlmon.dll
      0x3dfd0000 - 0x3e1b9000 C:\WINDOWS\system32\iertutil.dll
      0x5ad70000 - 0x5ada8000 C:\WINDOWS\system32\uxtheme.dll
      0x74720000 - 0x7476c000 C:\WINDOWS\system32\MSCTF.dll
      0x755c0000 - 0x755ee000 C:\WINDOWS\system32\msctfime.ime
      0x35250000 - 0x35264000 C:\Program Files\Adobe\Adobe Flash Builder 4\configuration\org.eclipse.osgi\bundles\298\1\.cp\swt-gdip-win32-3555.dll
      0x4ec50000 - 0x4edfb000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6001.22319_x-ww_f0b4c 2df\gdiplus.dll
      0x356e0000 - 0x35721000 C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.nativelibs_4.0.1.277662\os\win32\x86\BridgeTalk.dll
      0x35860000 - 0x358ca000 C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.nativelibs_4.0.1.277662\libs\adobe_caps.dll
      0x77920000 - 0x77a13000 C:\WINDOWS\system32\SETUPAPI.dll
      0x77690000 - 0x776b1000 C:\WINDOWS\system32\NTMARTA.DLL
      0x71bf0000 - 0x71c03000 C:\WINDOWS\system32\SAMLIB.dll
      0x35730000 - 0x35747000 C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexbuilder.utils.osnative_4.0.1.277662\os\win32\x86\JNIToNativeBridg e.dll
      0x35cd0000 - 0x35cda000 C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.1.277662\os\win32\x86\amt_win_jnilib.dll
      0x78480000 - 0x7850e000 C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4974_x-ww_d889290f\MSV CP90.dll
      0x78520000 - 0x785c3000 C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4974_x-ww_d889290f\MSV CR90.dll
      0x35d00000 - 0x35de6000 C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.1.277662\os\win32\x86\amtlib.dll
      0x35e10000 - 0x35f24000 C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.1.277662\os\win32\x86\amtservices.dll
      0x76d60000 - 0x76d79000 C:\WINDOWS\system32\IPHLPAPI.DLL
      0x4d4f0000 - 0x4d549000 C:\WINDOWS\system32\WINHTTP.dll
      0x361c0000 - 0x3622a000 C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.1.277662\os\win32\x86\adobe_caps.dll
      0x36350000 - 0x36378000 C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.1.277662\os\win32\x86\asneu.dll
      0x364a0000 - 0x36765000 C:\WINDOWS\system32\xpsp2res.dll
      0x76fd0000 - 0x7704f000 C:\WINDOWS\system32\CLBCATQ.DLL
      0x77050000 - 0x77115000 C:\WINDOWS\system32\COMRes.dll
      0x74ef0000 - 0x74ef8000 C:\WINDOWS\system32\wbem\wbemprox.dll
      0x75290000 - 0x752c7000 C:\WINDOWS\system32\wbem\wbemcomn.dll
      0x74ed0000 - 0x74ede000 C:\WINDOWS\system32\wbem\wbemsvc.dll
      0x75690000 - 0x75706000 C:\WINDOWS\system32\wbem\fastprox.dll
      0x76080000 - 0x760e5000 C:\WINDOWS\system32\MSVCP60.dll
      0x767a0000 - 0x767b3000 C:\WINDOWS\system32\NTDSAPI.dll
      0x76c30000 - 0x76c5e000 C:\WINDOWS\system32\WINTRUST.dll
      0x77a80000 - 0x77b15000 C:\WINDOWS\system32\CRYPT32.dll
      0x77b20000 - 0x77b32000 C:\WINDOWS\system32\MSASN1.dll
      0x76c90000 - 0x76cb8000 C:\WINDOWS\system32\IMAGEHLP.dll
      VM Arguments:
      jvm_args: -Xms256m -Xmx512m -XX:MaxPermSize=256m -XX:PermSize=64m -Djava.net.preferIPv4Stack=true -Dorg.eclipse.equinox.p2.reconciler.dropins.directory=dropins
      java_command: <unknown>
      Launcher Type: generic
      Environment Variables:
      PATH=C:/Program Files/Adobe/Adobe Flash Builder 4/jre/bin/client;C:/Program Files/Adobe/Adobe Flash Builder 4/jre/bin;C:\Program Files\ATI Stream\bin\x86;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\ATI Technologies\ATI.ACE\Core-Static;D:\1Dev\apache-ant-1.8.0RC1\bin;D:\1Dev\1Funtactix\Anima tionEarth\ci_scripts;D:\1Dev\1Funtactix\AnimationEarth\ci_scripts\moreshell;D:\1dev\php;D: \1Dev\php\ext;D:\1Dev\php;C:\Program Files\TortoiseSVN\bin;C:\Program Files\Java\jre1.6.0\bin;C:\Program Files\Java\jre1.6.0\bin\client;
      USERNAME=eyal
      OS=Windows_NT
      PROCESSOR_IDENTIFIER=x86 Family 6 Model 23 Stepping 10, GenuineIntel
      ---------------  S Y S T E M  ---------------
      OS: Windows XP Build 2600 Service Pack 3
      CPU:total 4 (4 cores per cpu, 1 threads per core) family 6 model 23 stepping 10, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
      Memory: 4k page, physical 2097151k(2097151k free), swap 4194303k(4194303k free)
      vm_info: Java HotSpot(TM) Client VM (14.2-b01) for windows-x86 JRE (1.6.0_16-b01), built on Jul 31 2009 11:26:58 by "java_re" with MS VC++ 7.1
      time: Mon Dec 20 10:01:49 2010
      elapsed time: 3 seconds
      Need help A.S.A.P!
      thanks.
