1. Re: How to create AVCHD DVD+R
John T Smith Dec 20, 2010 7:18 AM (in response to Howard Hoffman)I do not think you can burn a BluRay project to DVD... not and have it play, since the data rate for BluRay is much higher and a DVD player can't play the data rate of a BluRay project
As far as I know, you must author to DVD to be able to write and play a DVD
2. Re: How to create AVCHD DVD+R
bruce-tmvp Dec 20, 2010 8:06 AM (in response to John T Smith)your right,
you can put blu ray on a standard dvd but it
will only play on a blu ray player.
I put short blu ray projects on regular
dvds by making a blu ray image and then put the image on a dvd.
It has to be less than 4 GB to fit. Bigger then 4gb it's better to buy a blu ray dvd
to put the project on, blu rays now are cheaper then dual layer dvds.
3. Re: How to create AVCHD DVD+R
JSS1138 Dec 20, 2010 8:20 AM (in response to Howard Hoffman)How can I burn it to a DVD+DL?
Make it a DVD project, not a Blu-ray project.
4. Re: How to create AVCHD DVD+R
Howard Hoffman Dec 20, 2010 10:52 AM (in response to bruce-tmvp)I've tried to use TMT to play the folder as the source and it plays fine (chapter and menu all work fine).
Can I just burn this folder to DVD? Do I need a specific format (someone mentioned UDF)?
Thanks!
5. Re: How to create AVCHD DVD+R
John T Smith Dec 20, 2010 12:48 PM (in response to Howard Hoffman)You need to Google to find out the specifications for what will play in a DVD player attached to a TV
I **think** the maximum combined (video + audio) data rate is "something" like 9 MBS
You may be able to use a 3rd party app to burn your BluRay folder to a DVD... but it will NOT play in a set top DVD player due to the data rate, you would need to put that disc in a BluRay player, which is able to play back a higher data rate
If you want a DVD that will work in a set top DVD player... you simply must author to DVD, not BluRay
6. Re: How to create AVCHD DVD+R
Ann Bens Dec 20, 2010 1:50 PM (in response to Howard Hoffman)function(){return A.apply(null,[this].concat($A(arguments)))}
Thanks!
No, you have to make an BD Image (iso) not folder and use Nero or ImageBurn to burn it to DVD.
I also use DVD for small BD project.
7. Re: How to create AVCHD DVD+R
Howard Hoffman Dec 20, 2010 9:26 PM (in response to Ann Bens)Just tried to burn the folder with ImgBurn, UDF 2.50. It plays fine.
