6 Replies Latest reply on Dec 20, 2010 12:45 PM by TᴀW
    Add a hyperlink to another document? CS4
    TᴀW Adobe Community Professional & MVP
      How would one add a hyperlink to a document that refers to another document?
      The basic is:
      myDoc.hyperlinks.add(myHyperlinkTextSource, myHyperlinkTextDestination);
      How do I get "myHyperlinkTextDestination" if it exists in another, unopened InDesign document?
      I suppose I could open the document, get the Hyperlink destination, and then close it again, but in the UI this is not necessary (you simply browse to the required file and can then choose from a list of hyperlink destinations in that file). So how is this scripted?
      Ariel
        • 1. Re: Add a hyperlink to another document? CS4
          Next, I tried this:
          I opened the document and got it's HyperlinkTextDestination.
          Then I used it when adding the hyperlink to the main document:
          app.activeDocument.hyperlinks.add(mySource, myDestination) //myDestination is a hyperlink destination in another document.
          And I get the following error message:
          Cannot set this property to an object in another document.
          So I'm clearly on a wild goose chase here.
          But obviously this is possible since it is doable in the UI.
          Any and all help appreciated!
          Ariel
          • 2. Re: Add a hyperlink to another document? CS4
            Hi Arïel,
            Have you looked at HyperlinkExternalPageDestination?
            "A hyperlink destination that is a page in a document other than the document that contains the hyperlink source."
            (I have no idea how to use it, but one of its properties is "documentPath" -- the 'other' document. Sounds good, dunnit?)
            • 3. Re: Add a hyperlink to another document? CS4
              Hi Jongware,
              I did notice that, but:
              a. I have no idea how to use it either; and more importantly:
              b. I have to use textDestinations and not page destinations.
              Look, I'll explain why I need this stuff, and maybe you can tell me that
              I've got it all wrong:
              I'm creating an eBook of the Book of Psalms. The publisher wants a table
              of contents as a page (apart from the one that Adobe Digital Editions
              adds as a toolbar on the left).
              So I've got an InDesign book with 150 documents (one per psalm so it
              starts on a new page. InDesign CS4 here).
              So I've added a document with a list of the chapters. I was able to
              script a hyperlinkTextDestination at the beginning of each chapter
              (which saved me doing that 150 times).
              Now I want to script a textSource for each line in the TOC that will
              link up with the text destination
              Ideas suggestions etc. welcome, but especially I would like to know how
              to script a text source that points to a text destination in an external
              document.
              Ariel
              • 4. Re: Add a hyperlink to another document? CS4
                Well, having Googled "hyperlink TextDestination external" I finally came across this
                thread:
                http://forums.adobe.com/message/2474180
                Looks like he found a solution very similar to what I posted in the second message in this thread. I'm going to give it a shot.
                Ariel
                • 5. Re: Add a hyperlink to another document? CS4
                  Harbs. Level 6
                  You can create a hyperlink with a destination in another document, but I believe it must be open. You can open it with no window if you'd like.
                  The hyperlink must be added to the document with the source.
                  Harbs
                  • 6. Re: Add a hyperlink to another document? CS4
                    Hi Harbs,
                    Thanks. Yup, you're right, the external document must be temporarily
                    opened. The thread I linked to in my previous post shows exactly how
                    this should be done, and it finally worked for me.
                    Phew! That saved 150 tedious repetitions (well, actually 90. I had
                    already started doing the first 60 manually!)
                    Ariel
