2 Replies Latest reply on Dec 21, 2010 12:52 PM by bon_t
    Issue with replaying audio file at current position after pausing
    bon_t Level 1
      Hello,
      I am using Flex 4, ActionScript 3. In the AbstractPlayer.as class, the pauseTrack() method is as follows:
         soundPosition.stop();
         channel.stop();
         mIsPause = true;
         mPausePosition = channel.position;
      I implemented the playTrack() method in Player.as, which has the following code right at the beginning:
         if (mIsPause)
            replay();
            return;
      However, when I press the Play button after pausing, the audio file is played starting at the beginning. When I stepped through the debugger, the mPausePosition value is still present when playTrack() is called, but the mIsPause flag has been changed to false. I checked through my code and verified that the mIsPause flag is not reset before the check in playTrack().
      Does anybody have a fix / workaround for this issue?
      Thank you,
      Bon
