9 Replies Latest reply: Jan 28, 2011 2:30 PM by scotchfasterr RSS
    where are swcs and bin directories?
    BugsBn
      am also getting these errors (in  additon to others reported before) after latest SVN checkout (19495) and  importing insync sample project:
      where are the bin directories?
      cannot find them anywhere in the installation.
      find . -name Module.swc -print;
      nothing here...
      find . -name Module\* -print;
      doesn't show any bin dirs either.
      do we need to build all this using Maven?
      if so, what about all the build errors reported before?
      Description    Resource    Path    Location    Type
      unable to open '/Module/bin/Module.swc'    insync-modularExtended-api        Unknown    Flex Problem
      unable to open '/Observer/bin/Observer.swc'    insync-basic        Unknown    Flex Problem
        • 1. Re: where are swcs and bin directories?
          Nicolas Yuen Adobe Employee
          Hi Gary,
          I'm trying to reproduce your issue, have you imported the projects located in the libraries folder as well?
          /Module/bin/Module.swc,  '/Observer/bin/Observer.swc'  relates to projects that should be located in your workspace.
          • 2. Re: where are swcs and bin directories?
            BugsBn Community Member
            hi,
            appreciate your response - we are trying very hard to get this working.
            after trying to fix all the actionscriptproperties files manually, i built everything from scratch.
            after several attempts with maven, it built all the target libraries as snapshots, but it did not create the bin folder and move the swc's there.
            - but these ../bin/...swc seems to be also hardcoded in the actionproperties - not sure if i should also edit them.
            /libraries/Contract/target/contract-1.4-SNAPSHOT.swc
            ./libraries/Integration/target/integration-0.16-SNAPSHOT.swc
            ./libraries/IntegrationParsley/target/integrationParsley-0.16-SNAPSHOT.swc
            ./libraries/Module/target/module-0.15-SNAPSHOT.swc
            ./libraries/Navigation/target/navigation-1.4-SNAPSHOT.swc
            ./libraries/NavigationParsley/target/navigationParsley-1.4-SNAPSHOT.swc
            ./libraries/NavigationSpringAS/target/navigationSpringAS-1.4-SNAPSHOT.swc
            ./libraries/NavigationSwiz/target/navigationSwiz-1.4-SNAPSHOT.swc
            ./libraries/Observer/target/observer-1.14-SNAPSHOT.swc
            ./libraries/ObserverParsley/target/observerParsley-1.14-SNAPSHOT.swc
            ./libraries/Popup/target/popup-1.13-SNAPSHOT.swc
            ./libraries/PopupParsley/target/popupParsley-1.13-SNAPSHOT.swc
            ./libraries/PopupTest/libs/FlexUnit.swc
            ./libraries/PopupTest/libs/parsley-flex4-2.3.1.swc
            ./libraries/PopupTest/libs/spicelib-flex-2.3.1.swc
            ./libraries/Task/target/task-1.10-SNAPSHOT.swc
            ./libraries/Validation/target/validation-1.13-SNAPSHOT.swc
            who should create these bin folders referenced in .actionscriptproperties and move these swc into them?
            plz clarify this above issue - response to your question is in my next email.
            thanks.
            • 3. Re: where are swcs and bin directories?
              Now i did what you said below - i.e. import the libraries root folder also:
              Flex gives me these errors:
              configuration variable 'compiler.library-path' value contains unknown  token 'M2_REPO'    ContractTest        Unknown    Flex Problem
              configuration variable 'compiler.library-path' value contains unknown  token 'M2_REPO'    Integration        Unknown    Flex Problem
              configuration variable 'compiler.library-path' value contains unknown  token 'M2_REPO'    IntegrationDMS        Unknown    Flex Problem
              configuration variable 'compiler.library-path' value contains unknown  token 'M2_REPO'    IntegrationParsley        Unknown    Flex Problem
              configuration variable 'compiler.library-path' value contains unknown  token 'M2_REPO'    IntegrationTest        Unknown    Flex Problem
              in addition to the previous errors.
              Plz advise,
              Gary.
              • 4. Re: where are swcs and bin directories?
                You should declare the M2_REPO in your workspace linked resources: Preference->General->Workspace->Linked Resources.
                The M2_REPO variable should point to your local maven repository.
                Regarding the bin folders, you can either import the other projects in your workspace or copy the generated libs that you built with Maven (and rename them if you want).
                • 5. Re: where are swcs and bin directories?
                  Hi Nicolas,
                  Thanks for the response. Now, I got past that problem but after lot more time spent on trying to get this to work, am getting these errors below:
                  Plz let me know ASAP,
                  Gary.
                  Errors occurred during the build.
                    Errors running builder 'Integrated External Tool Builder' on project 'todo_flex_core'.
                      Launch configuration type id "org.eclipse.ant.AntBuilderLaunchConfigurationType" does not exist.
                  Possible causes:
                      Missing specification of a launch type (missing plug-in)
                      Incorrect launch configuration XML
                  Possible causes:
                    Errors running builder 'Integrated External Tool Builder' on project 'todo_flex_shell'.
                  Possible causes:
                  Possible causes:
                    Errors running builder 'Integrated External Tool Builder' on project 'todo_flex_todolist_lib'.
                  Possible causes:
                  Possible causes:
                    Errors running builder 'Integrated External Tool Builder' on project 'todo_flex_todolist'.
                  Possible causes:
                  Possible causes:
                    Errors running builder 'Integrated External Tool Builder' on project 'todo_flex_android'.
                  Possible causes:
                  Possible causes:
                  • 6. Re: where are swcs and bin directories?
                    It seems that you do not have the ant plugin install on your Flash Builder. Which version of the builder are you using?
                    • 7. Re: where are swcs and bin directories?
                      Am using latest greatest 4.0.1 with 4.1sdk.
                      (Only temporarily used 3.4sdk to try and get older version of Insync (on Wiki) to run)
                      Under plugins, it shows org.apache.ant installed - 1.7.1...
                      So much time spent on this - plz let me know how to get beyond all these issues and run the app,
                      Thx
                      Gary
                      • 8. Re: where are swcs and bin directories?
                        scotchfasterr
                        I'm in exactly the same situation. I'm using Flash Builder Standard 4.0.1 (build 277662) along with the 4.1 Flex SDK. I've checked out the project http://opensource.adobe.com/svn/opensource/cairngorm3/trunk/samples/insync/insync-basic and when I try to build it I get the error "unable to open '\Observer\bin\Observer.swc'".
                        I think I have the Ant plug-in installed. That is, if I try to install from Ganymede Update Site \ Java Development \ Eclipse Java Development, I get the message "Eclipse Java Development Tools will be ignored because it is already installed."
                        Other things I've tried:
                        1) Setting up Maven (it works).
                        2) Getting http://opensource.adobe.com/svn/opensource/cairngorm3 to my local folder C:\Program Files (x86)\Adobe\Adobe Flash Builder 4 Plug-in and setting the environment variable M2_REPO to C:\Program Files (x86)\Adobe\Adobe Flash Builder 4 Plug-in\cairngorm 3\maven-repository.
                        This really should not be so hard.
                        • 9. Re: where are swcs and bin directories?
                          scotchfasterr Community Member
                          I eventually got this to work by creating a brand new project and copying in files. A description of what I went through and a ZIP file containing the fixed project can be found here:
                          http://journeysinflexland.wordpress.com/2011/01/28/wwcbd/
