1 Reply Latest reply on Nov 7, 2012 6:17 AM by alam_84
    Undo/Redo with InDesign Server
    PeterPow
      Hello guys,
      is it possible to implement a undo/redo functionality as the client supports on the indesign server? The only method I found is the "revert"-method of the document object which turns the document back to the state before the last save operation. Is there a step-by-step undo method also?
        • 1. Re: Undo/Redo with InDesign Server
          alam_84 Level 1
          Hi Peter,
          I am also looking for the same thing.
          As we know that indesign server does not have an undo() method. then I could try to achieve it as follows
          1. Create a scriptable plugin and add a method UndoChange
          2. Used
          ICmdHistory::CanUndo and
          ICmdHistory::Undo
          methods to achieve undo functionality and found that it works fine for indesign desktop but on indesign server ICmdHistory::CanUndo fails.
          Does InDesign server has any limitation on undo?
          Any help here will be appreciated.
          Thanks and Regards,
          Alam
