1 Reply Latest reply on Dec 21, 2010 4:24 AM by flex2008
    Hide a VBOX based in IDs( Ids are in variable)
    194642537 Level 1
      Hi ,
          I have  a function in action script where I am creating a VBOX whose id will be in a variable.
      var str:String="abc";
         funcrtion xyz.......()
                var vbox:VBOX=new VBox();
           vbox.id=str;
        Now in another function I want to hide this vbox .... How can I access the id of that Vbox and hide it?
        Can anybody please help?
        • 1. Re: Hide a VBOX based in IDs( Ids are in variable)
          flex2008 Level 3
          Create a custom event say VBoxEvent
          package
              import flash.events.Event;
              import mx.containers.VBox;
              public class VBoxEvent extends Event
                  public static const VBOX_CLICKED:String = 'vBoxClicked';
                  private var _vboxInstance:VBox;
                  public function VBoxEvent(type:String, vBoxInstance:VBox,bubbles:Boolean=false, cancelable:Boolean=false)
                      super(type, bubbles, cancelable);
                      this._vboxInstance = vBoxInstance
                  override public function clone():Event
                      return VBoxEvent(type,_vboxInstance,bubbles,cancelable);
                  public function get vboxInstance():VBox
                      return _vboxInstance;
          Now in your xyz add a click event listener for the created vbox
          function xyz()
              var vbox:VBox=new VBox();
              vbox.id=str;
              vbox.addEventListener(MouseEvent.CLICK,onVBoxClick);
          In the click handler,dispatch a VBoxEvent with bubbles true after setting the vboxInstance with the event.currentTarget property.
          private function onVBoxClick(event:MouseEvent):void
              dispatchEvent(new VBoxEvent(VBoxEvent.VBOX_CLICKED,event.currentTarget as VBox,true))
          Add the VBoxEvent listener with capture true in the creationcomplete event handler of parent component
          private function creationCompleteEventHandler(event:Event):void
              this.addEventListener(VBoxEvent.VBOX_CLICKED,vBoxClickHandler,true);
          In the VBoxEvent handler in parent component,set the visible to false using    vboxInstance property in the VBoxEvent
          private function vBoxClickHandler(event:VBoxEvent):void
              event.vboxInstance.visible = false;
