1 Reply Latest reply on Dec 21, 2010 5:14 AM by saisri2k2
    HttpService : Getting ArrayList to ArrayCollection .
    kiran7881 Level 1
      Hi ,
        In my Servlet , i am getting data into an  ArrayList (Java) .
      I am using
      PrintWriter out = response.getWriter();
      out.println("One");
      out.println("Two");
      out.println("Three");
      out.println("Four");
      Now , inside my Flex UI on to the result function call
      public var ac:ArrayCollection  = new ArrayCollection();
      public function getData(event:ResultEvent):void
      ac =  event.result as ArryCollection
      Is this Correct ?? Please suggest . Thanks .
        • 1. Re: HttpService : Getting ArrayList to ArrayCollection .
          saisri2k2 Level 4
          Nope... you wil get
          one
          two
          three
          four
          as the responnse.. becuse they are strings. If you want array list, use blazeds. or
          if you send data like
          one,two,three,four
          then do (event.result as String).split(',')
          will return array. nd you can convert to array collection later. ac = new arrayCollection( (event.result as String).split(','))
          if none of the above work for you .. use a xml in the response like the following.. and parse it in the UI
          printWriter.println("someHugeXmlString");
          In UI
          (event.result as XML).one
          (event.result as XML).two
          (event.result as XML).three
          Message was edited by: saisri2k2
