5 Replies Latest reply on Dec 21, 2010 10:42 AM by SpaghettiCoder
    Can I sort a datagrid by DataGridColumn
    DesOC1
      I have a DataGrid and I want to sort the data by the dataField "date" by default before the table is output to the FrontEnd? Is this possible?
      <mx:Panel width="95%" height="90%" title="FlexList1">
      <mx:DataGrid dataProvider ="{voiceAuthLogging}" width="100%" height="100%" id="datagrid1" editable="true">
        <mx:columns>
                       <mx:DataGridColumn headerText="Row#" labelFunction="lfRowNumError" width="42" textAlign="center"/>
                       <mx:DataGridColumn dataField="date" headerText="DATE" showDataTips="true"/>
                       <mx:DataGridColumn dataField="employeeid" headerText="EMPLOYEE" showDataTips="true"/>
                       <mx:DataGridColumn dataField="comment" headerText="COMMENT"/>
                       <mx:DataGridColumn dataField="appusage" headerText="APPUSAGE"/>
                       <mx:DataGridColumn dataField="age" headerText="AGE"/>
        </mx:columns>
      </mx:DataGrid>
      </mx:Panel>
      Thanks.
      D
        • 1. Re: Can I sort a datagrid by DataGridColumn
          SpaghettiCoder Level 3
          var _mysortField:SortField = new SortField("date", true, false, true);
          var _mySort:Sort = new Sort();
          _mySort.fields = [_mySortField];
          yourArrayCollection.sort = _mySort;
          yourArrayCollection.refresh();
          • 2. Re: Can I sort a datagrid by DataGridColumn
            DesOC1 Level 1
            Hi, I have done this (code below) and it has not worked. My Collection is called authLogging. This has not worked. Apologies, I'm fairly new at Flex. I've called the function in the init()  function.
            Any other idea?
            private function sortDataGrid(): void
            var _mySortField:SortField = new SortField("date", true, false, true);
            authLogging.sort = _mySort;
            authLogging.refresh();
            • 3. Re: Can I sort a datagrid by DataGridColumn
              When you say it doesn't work, it simply doesn't do anything...and it doesn't throw a error message right?
              1. do a trace in init, make sure it's being executed
              2. do a trace in sortDataGrid() make sure it's being executed here as well
              If both of those functions are executed and the app doesn't throw an error msg,then post your init function, so we can see what's going on there...
              • 4. Re: Can I sort a datagrid by DataGridColumn
                <s:Application
                xmlns:fx="http://ns.adobe.com/mxml/2009"
                xmlns:s="
                library://ns.adobe.com/flex/spark"
                xmlns:mx="
                library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
                <fx:Script>
                <![CDATA[
                import mx.collections.ArrayCollection;
                import mx.collections.Sort;
                import mx.collections.SortField;
                private var array:Array = [
                {employeeid:
                "john", age:21, date:"2010-11-21"},
                {employeeid:
                "jane", age:12, date:"2009-12-24"},
                {employeeid:
                "jack", age:64, date:"2009-01-15"},
                {employeeid:
                "jill", age:32, date:"2008-04-01"}
                Bindable]
                private var yourArrayCollection:ArrayCollection = new ArrayCollection(array);
                private function sort(event:MouseEvent):void
                var _mySortField:SortField = new SortField("date", true, false);
                </fx:Script>
                <mx:DataGrid dataProvider="{yourArrayCollection}" id="datagrid1" editable="true" x="10" y="29">
                <mx:columns>
                <mx:DataGridColumn headerText="Row#" width="42" textAlign="center"/>
                </mx:columns>
                </mx:DataGrid>
                <s:Button label="sort" click="sort(event)" x="10" y="0"/>
                </s:Application>
                • 5. Re: Can I sort a datagrid by DataGridColumn
                  posted code that I tested on...
                  made a slight change to
                  because you're sorting numbers rather than strings...other than tha the sort function should be working...
