2 Replies Latest reply on Dec 21, 2010 11:42 PM by Redade
    Dynamic DataGroup in Datagroup
    Redade
      I am trying to create datagroups in datagroups at runtime.
      For example:
      there are 3 (could be 5 or 1) categories in pictures session,
      1. has 6 albums (changeble)
      2. has 4 albums (changeble)
      3. has 8 albums (changeble)
      i need to create 3 panels first and after that i need to create 6 subpanels in 1. panel, 4 subpanels in 2 panel and 8 subpanels in 3. panel.
      I tried so many ways but i couldnt make it work.
      any Help ?
      sample:
      panel - main panel there is only one
           datagroup - categories data group
                itemrenderer
                     component
                          itemrenderer
                               panel - categories panel (changeble count) so i m suing datagroup and itemrenderers here
                                    datagroup - albums datagroup
                                         itemrenderer
                                              component
                                                   itemrenderer
                                                       panel - albums panel (changeble count) so i m suing datagroup and itemrenderers here
      i need to create this scheme at runtime...
        • 1. Re: Dynamic DataGroup in Datagroup
          UbuntuPenguin Level 4
          Yo dawg,
            I heard you like itemrenderers, so I put an itemrenderer in your itemrenderer so you can render while you render...
          • 2. Re: Dynamic DataGroup in Datagroup
            Redade Level 1
                      itemrenderer
                           component
                                itemrenderer
                                               itemrenderer
                                                    component
                                                         itemrenderer
            As you can see i m using itemrenderer inside the other one. But in this way i couldnt set data to the inside renderer. I am watching the arraylists, till it came to the second itemrenderer everything is ok but when it came to second one, arraylist is empty always. So the second datagroup does not create related itemrenderers.
