9 Replies Latest reply on Dec 21, 2010 5:16 PM by learner_doug
    flex 4 custom dropdownlist
    Zolotoj Level 3
      I have googled it for hours. Any sample?
        • 1. Re: flex 4 custom dropdownlist
          learner_doug Level 1
          Here is one that loads external swfs using an external XML file (not shown) to populate the list via httpService:
          <s:Group
          xmlns:fx="http://ns.adobe.com/mxml/2009"
          xmlns:s="
          library://ns.adobe.com/flex/spark"
          xmlns:mx="
          library://ns.adobe.com/flex/mx" width="400" height="300" creationComplete="dropDownListXML.send()" xmlns:components="components.*">
          <fx:Declarations>
          <!-- Place non-visual elements (e.g., services, value objects) here -->
          <s:HTTPService id="dropDownListXML" url="xmldata/EBSnewMileStones.xml" />
          </fx:Declarations>
          <fx:Script>
          <![CDATA[
          import components.DropDownHeader;
          import mx.events.FlexEvent;
          import spark.events.IndexChangeEvent;
          protected function msDropDown_changeHandler(event:IndexChangeEvent):void
          var dropDownSelection:int = msDropDown.selectedIndex;
          if(dropDownSelection == 0)
          closeDropMovie_btn.visible =
          true;
          dropDownLoader.load(
          "lessons/EBS_new_Milestone1.swf");
          if(dropDownSelection == 1)
          true;
          "lessons/EBS_new_Milestone3.swf");
          if(dropDownSelection == 2)
          true;
          "lessons/EBS_new_Milestone5.swf");
          if(dropDownSelection == 3)
          true;
          "lessons/EBS_new_OW_MS18.swf");
          if(dropDownSelection == 4)
          true;
          "lessons/EBS_new_WH_MS14.swf");
          if(dropDownSelection == 5)
          true;
          "lessons/EBS_new_FO_MS7.swf");
          protected function closeDropMovie(event:MouseEvent):void
          dropDownLoader.unloadAndStop();
          false;
          msDropDown.selectedIndex = -1;
          </fx:Script>
          <s:ComboBox id="msDropDown"
          dataProvider="
          {dropDownListXML.lastResult.milestones.milestone}"
          x="
          10" y="10" width="240"
          chromeColor="
          #CCCCCC" color="#000000"
          labelField="
          name"
          change="msDropDown_changeHandler(event)"
          <mx:SWFLoader id="dropDownLoader" x="-580" y="-20" depth="100" />
          <s:Button id="closeDropMovie_btn" depth="101" label="X-Close" x="354" y="-20" click="closeDropMovie(event)" visible="false"/>
          </s:Group>
          • 2. Re: flex 4 custom dropdownlist
            Zolotoj Level 3
            Not sure  I understand. Where exactly are extending DropDownList?
            • 3. Re: flex 4 custom dropdownlist
              Sorry 'bout that.  This was as custom component dropdown.
              I'm sure you have already seen the follow basic DropDownList extending DropDownList, but just in case.  Good luck!
              • 4. Re: flex 4 custom dropdownlist
                saisri2k2 Level 4
                wht re we trying to customize here?
                • 5. Re: flex 4 custom dropdownlist
                  Is your question regarding the functionality of the component, or are you questioning why I considered it "custom?"
                  Regarding the former:  the component "groups" the combo fox, xml, swf player and quit button together.
                  Regarding the latter:  I probably should not have called that custom.
                  • 6. Re: flex 4 custom dropdownlist
                    saisri2k2 Level 4
                    from the question(Original post) I could not figure out anything, If the requirements are given, atleast I could guide you in some direction / give the solution myself.
                    • 7. Re: flex 4 custom dropdownlist
                      Actually I am not the person asking the question.  I had provided some code to someone who wanted to see an example of a dropdown - I posted an example which I use.  I was not asking a question in this case.
                      Sorry for the confusion and thanks for trying to be helpful.
                      doug
                      • 8. Re: flex 4 custom dropdownlist
                        saisri2k2 Level 4
                        yea, understood!  I was asking the person who strted the thread!
                        • 9. Re: flex 4 custom dropdownlist
                          I'll need to be more careful in the future.
