0 Replies Latest reply on Dec 21, 2010 4:04 PM by Neat Gadget
    Tab with Cellrenderer and Combobox
    Neat Gadget Level 1
      When using Cellrenderer to display a combobox in a datagrid, there is an issue with using Tab. If you tab through the cells, it will cause the combobox to erase. To fix this the column needs to be set to non-editable. Problem with doing this is that then you cannot tab to the cell where the combobox is.
      Does anyone know a work-around this?
