9 Replies Latest reply on Dec 28, 2010 8:38 PM by Jay Knobbe
    Another HD setup question
    Jay Knobbe Level 1
      This is my system...
      CS5 Production Premium
      Windows 7 64 bit
      HAF 932 X case with 4 fans
      Gigabyte GA-X58A-UD3R  v2.0
      i7 950
      EVGA GTX 470
      G.SKILL PI Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7T-6GBPI
      Hyper 212 plus cooler with an additional fan
      1 Velicoraptor 300gb
      4 F3 1tb drives
      1 WD Black 1tb 32mb cache
      1 WD Black 2tb 64mb cache
      Coolermaster 1000w PSU
      I need some advice on how to set up these drives
      This is what I was thinking...
      WD Velo for the OS
      WD 2tb for storage
      WD 1tb for back up
      and not sure on the 4 F3's
      Cannot afford a controller card right now.
      I have many hours of SD footage to load, along with newer HDV files
      Also, if i read correctly, I should set them up with no partitions?
      Thank You
        • 1. Re: Another HD setup question
          Harm Millaard Level 7
          First, make your memory 3 x 4 GB sticks. 6 GB is not enough for decent performance.
          Use your 4 F3's in two raid0 arrays on the mobo. Look here for the allocation of file types: Adobe Forums: Generic Guideline for Disk Setup
          Partitioning will only cause wear and tear on your disks and make them slower, so don't use partitions.
          • 2. Re: Another HD setup question
            Jay Knobbe Level 1
            Thanks Harm,
            I do have 6 sticks of this ram. I just couldn't swing the extra expense of the 4g sticks when I bought them 3 months ago.
            • 3. Re: Another HD setup question
              Jim_Simon Level 9
              Here's a couple of options that I might choose:
              Velociraptor - System
              F4 - Projects/Scratch
              F4 - Media
              F4 - Export
              F4 - DVD Images
              WD 2TB - Backup.
              WD 1TB - Leave on a shelf as a replacement if an F4 ever dies.
              Or my preferred config:
              F4x3 - Media (RAID 3 using an Areca card)
              WD 1TB - Exports
              WD 2TB - DVD Images and Backup.
              • 4. Re: Another HD setup question
                Jim,
                You must have overlooked this statement by the OP:
                in which case an Areca card is out of the question, and secondly I think you are better off with a 4 disk raid3 than a 3 disk array. Put the DVD images on the 2 TB WD.
                • 5. Re: Another HD setup question
                  Jim_Simon Level 9
                  I didn't miss it.  But I did put it second, thinking that someday a card might be possible.
                  I'd not argue with the 4 disk array in theory, but then you're short one disk for my preferred setup of System/Projects/Media/Export/Backup.  (And I put them in that order on purpose.  As you drop disks, the last one in the sequence is combined with the one before.  So that with only four disks, you'd combine Backup and Export.  With three, you'd combine Backup, Export and Media.  Etc, etc.  The OP has enough for all five categories using a 3 disk array, which is why I suggested it.)
                  • 6. Re: Another HD setup question
                    Jay Knobbe Level 1
                    This is how I connected my HD's
                    ICH10R ports. Total of 6
                    4 1TB F3's (will try to set up in a Raid 0)
                    1 300BG WD Velo for the OS
                    eSATA connector from the front panel of my HAF X case
                    Marvell 9128 ports. Total of 2
                    2TB WD Black
                    1TB WD Black
                    GSATA (Gigabyte chip?) Total of 2
                    BR DVD burner
                    Open
                    Does this look like a good set up?
                    I question whether I should have the OS drive on the same chip as the drives that I will Raid.
                    Also I grew weary of trying to figure out what fans I should plug into what headers, so I removed the large Molex 4 pin connector and just plugged them into the MOBO willy nilly except for the CPU fans, which was obvious.
                    I'm learning as I go but it is a Sloooooowwwwwwww process.
                    • 7. Re: Another HD setup question
                      Jay Knobbe Level 1
                      Hi All,
                      I was kind of looking for a thumbs up or thumbs down as to how I connected my drives & fans to the MOBO before I turned it on and started to configure the drives.
                      It seems that there should be a purpose in plugging certain drives into the Intel chip vs the Marvell or Micron chip.
                      Your guidance is appreciated.
                      • 8. Re: Another HD setup question
                        Colin Brougham Level 6
                        The Marvell is the SATAIII (6Gbps) controller; the JMicron is... junk. Here's how I'd do it:
                        ICH10R - set to RAID mode in BIOS
                        4 1TB F3 - RAID 5 (hit Ctrl+I during boot up when you see the ICH10R screen; build a RAID5 with these)
                        2TB WD Black
                        1TB WD Black
                        Marvell - set to AHCI mode in BIOS
                        GSATA
                        BR DVD burner
                        Open
                        • 9. Re: Another HD setup question
                          Jay Knobbe Level 1
                          Thanks for the guidance. It's what I was looking for.
                          And thanks to Harm & Jim also.
